7080 battery box battery connections |
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 793 |
Topic: 7080 battery box battery connectionsPosted: 08 Mar 2024 at 8:44pm |
Hi I have a 7080 and Im running with 2 batteries. The problem I have is that the batteries ground through the battery box individually with a bolt. I have cleaned up the holes and even used new bolts but it seams like I have a hard time maintaining a ground with one of the batteries? The inside battery the bolt goes threw the battery box and into another ground strap that goes to the casting on the transmition (good connection) The outer battery is set up to ground through the box in which I get a terrible connection and the tractor ends up cranking on just one battery which isnt enough. Any ideas? Would grease around the bolt and the surface help maintain a good clean connection?
Joined: 11 Sep 2009 Location: illinois Points: 91050 |
Posted: 08 Mar 2024 at 8:57pm |
add a ground strap from the 2nd battery to the first, or to the case bolt..
nickia
Posted: 08 Mar 2024 at 9:01pm |
ok thanks steve I was thinking about that but was looking for something simple that I could of missed. and your right it would be a easy solution
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5199 |
Posted: 09 Mar 2024 at 6:46am |
I have changed a couple smaller tractors (185 and 7000) over to one large (battery size 4DLT) battery for the same reason. I was finding bad connections on one battery and one battery was doing all the work.
I like one large battery much better.
Unit3
Posted: 09 Mar 2024 at 12:52pm |
For what it’s worth, I have gotten rid of the lug style and went with stud bolt batteries. (7045 & 7080) The front battery has the pos + in front and same for the rear. That puts the negative stud out first when they swing out. I undo one nut and they are disconnected. 8000’s have negatives in front and they are undone as well. Old tractors, trucks, and combines aren’t getting any newer. And neither are their wiring.
