7080 Alis Chalmers |
Braylen Bruns ![]() Bronze Level ![]() ![]() Joined: 19 Aug 2023 Location: 45883 Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Aug 2023 at 8:07pm |
When you just start the tractor it does not go into gear unless you fight it and force into the gear you want. But after a while when it gets hot it shifts great and there's no problems. Does anyone know what this may be.
Clutch cable needs adjusted and new bushings in pivot. With engine shut off, take all free play out of clutch pedal, after replacing bushings. MACK
Ok I will get that all done I will let you guys know if it will work.
