706-G forklift
Postville View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Postville Quote  Post ReplyReply Direct Link To This Post Topic: 706-G forklift
    Posted: 14 Aug 2020 at 6:09pm
I have a 706-G forklift that jumps when shuttle shifting. It also creeps. I  have the idle down to 600 rpms. It is hard to come into a pallet. If I use the clutch there is no feathering, machine still lurchs.
Oil level good, oil looks a little milky. Using red hydraulic fluid, ATF.
How can I adjust the torque converter to stop this? I would think the machine should remain stationary until engine revs up.
Any tips? Thanks, Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 6:26pm
First thing to do is change that milky oil.  water in oil makes it grabby...
Oh, and welcome to the forum, others with more knowledge of this model will be along...Wink
Edited by DiyDave - 14 Aug 2020 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Postville Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 6:43pm
I changed the oil today. Machine is better but still lurches some  when shuttle shifting, better in that it will stay stationary with a lot less brake pressure.I hope it will continue to improve.
I have a Hyster with a similar Alison transmission. This machine just sits there when you shift and moves when revving up the engine. Should the AC be similar?
I can't figure out how water gets into that case, is this from condensation?
Thanks for the tip. Hard to get an answer from a dealer.
Bob
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 10:50am
Herc-U-Lift in Mpls sold those machines - old mechanics there knew them - unsure of present group - might try their service dept for more info .
