706-C Forklift Engine Manufacturer |
Amos
Topic: 706-C Forklift Engine ManufacturerPosted: 26 Aug 2024 at 8:58pm |
I'm looking for a governor for the gas engine in my forklift, but do not know who manufactured the engine?
Understand it could be ford or continental or ???? is anyone familiar with these machines?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54696 |
Posted: 27 Aug 2024 at 4:37am |
Swinford's book says Perkins 4.203, gas or diesel Perkins 4.236 in the 706 C...
Amos
Posted: 27 Aug 2024 at 7:47am |
So its a Perkins 4.203 gas engine, then??
orangeman
Posted: 27 Aug 2024 at 8:52am |
Morning Amos: Perkins usually had a flat casting block machined into the side of the engine with the identifying numbers of the engine machined into the surface. At least that was the case for the 4-236 in the 715 and 715B series backhoes. The 706 AC Forklift shares some similar components (driveline) to the AC 700 series backhoes so therefore similar.
That said, I would recommend you take a small wire brush and get after the block and hunt around for a Perkins tag or see if you can find the casting it may be buried under grease and oil build-up. HTH's ~ Orangeman
Edited by orangeman - 27 Aug 2024 at 8:52am |
Joined: 11 Sep 2009 Location: illinois Points: 89172 |
Posted: 27 Aug 2024 at 3:56pm |
https://www.allischalmers.com/forum/706-b_topic41297.html
DIESEL was Perkins ........ GAS ...( Perkins G4-203 or G4-236 ) ... older had FORD Perkins only made a few variations of GAS engines.. most were diesel ... Sticker or TAG somewhere ?
Edited by steve(ill) - 27 Aug 2024 at 4:07pm |
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1004 |
Posted: 27 Aug 2024 at 6:25pm |
mine has the g4-203
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3603 |
Posted: 30 Aug 2024 at 2:35pm |
What’s the top of your 706c’s engine look like?
Does it have an overhead valve train with a tin valve cover(ford/Perkins)? Does it have a flat-top cast head with distributor sticking up in center of it(Continental)? My 706b has a transplant flat-head continental in it. Some previous owner probably replaced original Ford engine with it? Continentals are plentiful in the forklift world. Edited by AC7060IL - 30 Aug 2024 at 2:42pm |
