7060 seat help
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: 7060 seat help
    Posted: 2 hours 46 minutes ago at 7:57pm
I spent most of my day today in our 7060. Grandpa bought it new so it's definitely got sentimental valve to my dad brother and I. The seat suspension needs some attention. Are we better of trying to rebuild or fab in a different seat. Would like to try and keep it original if we can. Does agco or anyone sell a seat rebuild kit with all the bushings?
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 60 minutes ago at 8:43pm
Put an air ride in it .Several companies offer them . Easy installation. You won’t be disappointed. Had ours in a7045 for about 30 years now. Still use the original seat, just change out the bottom.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 53 minutes ago at 9:50pm
I put new bushings in my suspension and replaced the spring/shock assembly last fall in my 7000. I also put in a replacement seat, I think it was from vevor but I am considering going back to the original. My seat wasn't bad, just the suspension. I was considering an air ride, but did some measuring and decided against it. I think the 7060 has a little more room than the 7000. I bought all my pieces separate, but I did see a kit somewhere. I have included some pictures of the process.
https://photos.app.goo.gl/q1kdkt5MJpBgr9Dg8
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 51 minutes ago at 9:52pm
7000 and 7060 cabs the same size/width.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 35 minutes ago at 10:08pm
Same size and width, but the back is a little different. The 7000 doesn't have the flow adjustment under the seat and continues the taper to the floor.
Ted
