7060 seat help |
ToddnwIl
Topic: 7060 seat helpPosted: 27 Feb 2026 at 7:57pm |
I spent most of my day today in our 7060. Grandpa bought it new so it's definitely got sentimental valve to my dad brother and I. The seat suspension needs some attention. Are we better of trying to rebuild or fab in a different seat. Would like to try and keep it original if we can. Does agco or anyone sell a seat rebuild kit with all the bushings?
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1014 |
Posted: 27 Feb 2026 at 8:43pm |
Put an air ride in it .Several companies offer them . Easy installation. You won’t be disappointed. Had ours in a7045 for about 30 years now. Still use the original seat, just change out the bottom.
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 160 |
Posted: 27 Feb 2026 at 9:50pm |
I put new bushings in my suspension and replaced the spring/shock assembly last fall in my 7000. I also put in a replacement seat, I think it was from vevor but I am considering going back to the original. My seat wasn't bad, just the suspension. I was considering an air ride, but did some measuring and decided against it. I think the 7060 has a little more room than the 7000. I bought all my pieces separate, but I did see a kit somewhere. I have included some pictures of the process.
https://photos.app.goo.gl/q1kdkt5MJpBgr9Dg8 Ted |
Posted: 27 Feb 2026 at 9:52pm |
7000 and 7060 cabs the same size/width.
TedN
Posted: 27 Feb 2026 at 10:08pm |
Same size and width, but the back is a little different. The 7000 doesn't have the flow adjustment under the seat and continues the taper to the floor.
Ted |
Posted: 28 Feb 2026 at 6:44am |
I'm not there looking at what you have, but If it was mine, I'd be ordering parts from DJS tractor parts in Stockbridge, Michigan 49285. They have an 8-brass bushing kit for $35. They have a complete new seat shock/spring assembly for $120. They have the rubber bushings at each end of your old shock/spring. I think they have almost everything you'd need other than any of the shafts, which are different. I usually just buy long grade 2 or 5 bolts from Farm Fleet and make shafts for less $$$. If you re-use your old shock/spring assembly, get a short piece of exhaust tubing from AutoZone that can be used as a spacer to shim the coil spring downwards 3/4" and no more than 1 inch. I don't remember the diameter. I just have a length I just cut out of when I do one. This will make up for the springs shorter length after 50 years and get the seat back up to a more comfortable ride height. You won't believe the difference. In any area where the brass bushing has broken and has the hole wallowed out in the steel part, I buy 1/2" steel bushing material and cut to length and weld into the bad hole. Two of those linkage areas I always make the steel bushing stock piece long enough to replace two brass bushings at once for greater strength. Always drill a small hole on top to give it a squirt of oil now and then.
Edited by DrAllis - 28 Feb 2026 at 7:10am |
plummerscarin
Posted: 28 Feb 2026 at 7:18am |
Agree with DrAllis on the repairs and upgrade of the spring. Had that done on a 170. Remarkably better than it's worn down state
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 28 Feb 2026 at 7:51am |
Rebuild your existing suspension if you want to keep it stock. Mostly worn pins and bushings that cause problems.
TedN
Posted: 28 Feb 2026 at 10:30am |
I have rebushed four suspensions so far, my 7000 is the first time I have replaced the spring and shock. I couldn't believe the difference, and wouldn't do another one without replacing it. I was able to swap the front and rear pivot pins on the base because they wear in different spots. The pin under the seat I welded and ground back to size, and the one at the rear of the seat didn't have much wear and I was able to rotate it halfway. I have used anti-seize on the pins and bushings during assembly, but the DrAllis suggestion of a small hole to lubricate them sounds like a better idea.
Ted |
Thanks(1)
Posted: 28 Feb 2026 at 3:25pm |
The oil hole is for when I use a length of 1/2" steel bushing stock welded in oblong suspension holes to replace two bushings. So, I'm running a steel pin against a steel bushing, so a drop of oil once in a while is good.
Kevin210
Posted: 01 Mar 2026 at 10:10am |
I rebuilt the seat on the 210 and replaced bushings and pins
but the best piece of advice I can give is to take plenty of pictures of the seat assembly because no matter how many times you look at before you take one apart or how many pictures you take there always seem to be a spot you just can't remember how it goes unless you're lucky enough to have another sitting in the barn to look at. Just my 2 cents. |
