7060 Pto seals replacement again. |
Post Reply |
AC 426 power
Orange Level Access Joined: 01 May 2012 Location: Ohio Points: 519 |
Posted: 14 Dec 2019 at 9:03pm |
Got a couple of questions on replacing the seals on my PTO, how much torque should I put on the big nut of the shaft? first time I replaced it I had a Issue where the 1000 shaft actually rubbed on the output shaft when using the pto on 540 and got hot enough to actually damage the front seal and cause a leak again before the problem was noticed, which made me wonder if this problem could have been caused by not having enough torque on the nut? or any other idea as to why this would happen? taking it apart all the bearings and gears look to be fine and did not have any unusual wear or other signs of improper install.
LB0442
Orange Level Joined: 27 Dec 2014 Location: Boise ID Points: 767 |
Here is a picture from previous post I did on a dual pto install. Manual says to tighten that nut 20 inch pounds more than turning torque. Mine checked out at 185 inch pounds turning, so I tightened it down until it went to 205 to 210 inch pounds. Make sure you install the lock pin with new wire also. I would not over tighten it.
LB0442
It's been in there for about 200 hours. So far works great, no leaks no noise.
MACK
Sounds like front bearing or race is the problem. Are you sure the front race is not missing? MACK
AC 426 power
MACK
It would have to be on solid shaft, not hallow shaft. MACK
AC 426 power
Are you talking about the small signal bearing and race that the shaft rides on?
Dave H (NE)
Silver Level Joined: 11 Sep 2009 Location: Western NE Points: 288 |
yes that is the one Mack is talking about
MACK
Yes, the bearing on the front end of the longest shaft. MACk
AC 426 power
Bearing looks fine and race looks to be correct. Was wondering if it would be wise to re use the old big seal that I just installed this spring? Or should I just bite the bullet and replace it again? looks fine, but it is $50 through Agco.
LB0442
There is a torrington bearing between the 2 gears, is that still good and the washer also?
AC 426 power
LB0442
Well here are the install pages from the manual possibly that will help.
AC 426 power
AC 426 power
LB0442
Yes, I can't remember what size socket but one fit on the PTO shaft. I have a couple of different torque wrenches but the dial type ones work best for that. Similar procedure to installing differential pinion bearings.
AC 426 power
AC 426 power
Success! Got it all back together and no leaks or notices and most importantly no contact with the 1000 shaft, ran the grain cart all day with no issues.
Post Reply | |
