7060 PS hi-low cable
Lady Lacey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lady Lacey Quote  Post ReplyReply Direct Link To This Post Topic: 7060 PS hi-low cable
    Posted: 21 Mar 2021 at 11:13am
So my hi/lo cable continues to work free from the two hole strap inside the shifting console. Does the block spacer need to be mounted a certain way? Also, curious to know if you guys have modified it to help hold the cable in place?
Thanks,
Lacey and Garry
7040, 7030, 185, D17 IV, 720, Case 430
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2021 at 9:18pm
Have saw threads worn out in consol. Replace Allen head bolts with grade 5 bolts 1/4 -1/2 inch longer. Make spacers for bolts to get bolt heads away from cable.                 MACK
