7060 Power Shift Has Me Puzzled |
Post Reply | Page 12> |
tthams
Bronze Level Joined: 18 Oct 2020 Location: Denison, Iowa Points: 140 |
Posted: 01 Nov 2020 at 10:06am |
I was hoping someone change help me to understand what might be happening with our Allis 7060 power shift. I have roughly 15 hours on this tractor that I just bought and recently it started acting up. I have not changed or done anything different to the power shift at all.
I went to start it yesterday (Friday), and it worked great for around 5 minutes and then it wouldn't move. I checked the power shift filter and the oil around it was black, with microscopic specks of iron fillings. Yet when I pulled the dipstick to the oil under the seat it was fairly clear. I ended up changing the PS filter with one from AGCO, and everything was back to normal. I had corn stalk bales to get off the field on Friday, and I was shifting a lot in the low side. Once I shifted it to 6 gear and the rpms on the tractor went way down like the transmission brake was kicking in. I stepped in the clutch and drove it in 4th gear for a while. Eventually I got brave and tried it in 6th gear and it went fine. About an hour in using the tractor didn't want to move in any gear. I could shut the engine down and restart it within 15-20 second and it would run fine until I had to put it in reverse. It just stalled with the clutch out. I would shut the engine down and then start it up again and put it into reverse and it would work fine until I had to put it in reverse, and I would have to kill the engine and restart the process. There were a few times where it was a delayed reaction, but it would engage. I ended up parking it Friday. I checked the transmission oil on Sat**day before I started it, and was again still normal hydraulic color, but a little on the dark side, and the low side of normal. I decided to add a little trans/hydraulic oil, and ended up over filling it a little and was going to drain some out when I got it out of the shop. I started it up and heard a whining sound coming from the PS valve body on the passenger side of the tractor. It started to drip oil from the valve body also. It was a very small amount, but this was a new leak. I also noticed the hose on the top of the PS canister (back right of the tractor) was whining. When I felt the top hose, you could feel it pulsing. I ended up taking the filter off again and the oil was again all black in the PS canister. I also noticed that rubber o ring seal was torn on plastic piece that sits on top of the PS filter. I thought this was odd because I just replaced the o-ring along with the filter because it was torn when I took the off the first time. So the rubber o-ring was torn again within 2 hours of use? I find that odd. Anyway I replaced the o-ring with another one, and the noise and the whining was instantly gone and everything worked great. We hauled manure and I only got two loads hauled before the whining in the PS valve body and the hose on the top of the PS filter came back. I parked it on Sat**day, and I have not looked at the PS filter to see if the o-ring in bad again. I won't be back to the farm until next weekend, and I am going to start with draining all the oil in the transmission and starting with a new filter (AGCO) and an o-ring again and see if that doesn't help. My question is is there a suction screen somewhere on the PS transmission (not the filter in the canister) that might be getting plugged. It acts like it is not getting enough transmission fluids to drive the tractor. When I shut the tractor down, and then restart the tractor it works again which makes me think something in getting plugged, and the moment the pressure drops with the tractor off, the particles settle down. I am thinking new oil might help with the valves not sticking. I am also hoping to adjust the idler spool and the transmission brake and see if that doesn't help. I just haven't had the chance yet. The hose line to the Gerotor pump looks fine. Any reason why the transmission dipstick under the seat is not the dark colored oil coming from the filter canister? I am wondering if the clutches are slipping some creating the black color. Currently the clutch is almost completely out before the clutch engages maybe 80%. If I adjust the transmission brake wouldn't that also have some effect on the clutch engaging sooner?
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 957 |
Seems like you have a tractor with +/- 6000 hours, and never had a trans/hyd oil change... the trans is probably cooked!
Let's see what others have to say. |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8091 |
Thanks(1)
Oh boy ron has great advise dont he,,
tthams
I am hoping it is something simple. I took a chance on the tractor because it has signs that transmission work has been done to it. The hour meter on it shows 4600 hours. Here is a picture of what I mean. It looks like the they have been in the tractor recently. The PS filter says 4/19 when it was changed.
uploads/21457/IMG_20201006_174514086.jpg |
tthams
IMG_20201006_174514
tthams
Lets try posting the picture another way.
There is writing on it showing work was done it is around 200 hours ago.
tthams
Here is a picture of the transmission valve body. The paint is worn off around nuts on the valve body to indicate work done on it also. It have a new paint job on the tractor also in the last two years.
bigal121892
Orange Level Joined: 05 Jan 2010 Location: Nebraska Points: 800 |
Underneath the transmission, there is a square plate, if you unbolt that you will find a suction screen for the transmission pump. This may need cleaning. Be sure the transmission is drained first.
Orange Level Access Joined: 12 Sep 2009 Points: 20187 |
Drain the oil and inspect that screen. Sounds like some real dirty oil from a clutch valve sticking and then a clutch drags.
tthams
Thanks everyone for the reply. I am glad to know there is a mesh screen in addition to the filter. I am eager to get to the farm next weekend and check things out.
MACK
I'm guessing when you remove the bottom plate , there is going to be a bunch of crap on it . If there is, might as well get it in the shop for a rebuild. MACK
tthams
I was kind of wondering that also Mack. I am still hoping it is something simple. When I went and looked at the tractor it has signs of of scheduled maintance being done.
I was excited to find this info because it showed that the tractor had around 300 hours put on it on it in over 10 years. The PS filter canister had 4-19 written on the side of it also. I have around 15 hours on it and put it to work and it worked fine the first day pulling a 200 bushel wagon and moving bales off the field. Looking at everything, I wonder if that was the first time it saw work in a few years, and it stirred stuff up in the tranny. Then the next day I use it I get the problem. When the o-ring tore the second time there was a small chunk we couldn't find. I am wondering if it is caught in the screen. I took the first o-ring that was torn into town at a JD place and got 2 o-rings that looked real close to the torn one. I am planning on going to the AGCO dealer (farther away) and get a true o-ring meant for it. Part of me is wondering if the o-ring I put in there isn't the correct size. I just fine it odd that a tractor that was well kept would not of had the transmission fluids changed often. I am still thinking I need to do some adjustments on the clutch and the idler spool. kept https://drive.google.com/file/d/1hVQFY6CVitz4yq_Zjvro3iACBpe2c3xE/view?usp=sharing |
A cut Oring in the filter winds up in the valve body, not the suction screen.
tthams
Would the small o-ring chunk get ground up eventually since it is rubber, or do I have to go in to the valve body and start digging around for it? What would you suggest Dr. Allis?
I would expect to find it in the Power Shift valve body. Your first priority is checking the suction screen condition. That will determine the next step.
tthams
Sounds good. I will try and take pictures of it this weekend of the screen and the condition, and share them.
tthams
Here are some pictures of the plate that I took off. I was not expecting to find two large chunks of wire.
Any idea where that could have come from? Again it looks like they replaced the Gerotor pump because it is not the maroon belly color. Could it have failed and the pieces come from that.
MACK
It is a ring from a planetary . Caused by a worn bushing that is NLA. Time for a complete rebuild. MACK
Clutch failure of some kind. Removal of the valve and a visual inspection will tell you which one. Get the tractor parked where you want to double split it before removing valve. Never seen oil that black before.
tthams
Thanks for the bad news. Still frustrated that it worked so well for the first 15 hours I had it, and then this. I am not familiar with overhauling a transmission.
Would the clutches slipping create the black oil or do you have better idea? The transmission dipstick was still clear before I dropped the oil which is still odd. Do anyone have an idea what I would expect to pay for a transmission overhaul on the tractor before I start calling around? Since it still drives and moves easily through the gears before I parked it, can I get by with just replacing the clutches?
DougG
Ive heard rebuild on an Allis Powershift was around $5000 a few years ago,
bigal121892
The last one we had done, was on an 8070, and it was $6,600.00, that was in 1994.
Orange Blood
Orange Level Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Cost is going to depend on finding parts, it sure looks like you are into some hard parts. Most of the hard parts in the trans are no longer available (NLA) most can be found at salvage yards, but that is a variable in the cost. If you are lucky and you really didn't toast much, and maybe can get away with seals, gaskets, and only a few good used parts, maybe a couple bearings..... you might be able to rebuild it yourself for under 2K in parts. Add oils filters coolants an AC charge, hoses, and if you can't do the work yourself, well then there you are.
Still in use:
Never touch the Air Conditioner. Unbolt components and lay them off to the left side out of the way.
Kevin in WA
Orange Level Access Joined: 08 Feb 2010 Location: Lynden, WA Points: 607 |
that wire looks like a section of wave spring from one of the clutch packs.
Orange Blood
Still in use:
rw
Silver Level Joined: 28 Oct 2009 Location: United States Points: 383 |
Mine broke the front bearing support at 5000 hrs. I did the labor and spent about 5500 ten years ago. The bearing support was 2500 as I remember. I possibly could have reused the clutch plates.
I think I would look into having this front bearing support checked for cracks in the threads as an early step in the decision process.
tthams
Thanks for the "bad" news everyone. I know a guy that use to work as a mechanic for Agco in Iowa. He is thinking $8,000-$10,000 depending on parts needed. He based that on the transmission work being around $6000 back in the 1990's. He is looking at starting in January.
He mentioned that I should get 5000 to 6000 hours before work will be needed again. So at 100 hours a year, I should not have to worry about the transmission for awhile.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11544 |
Do what you will, but for 8-$10,000 I'd be buying another tractor. Preferably, another 7060 and you'll have yours for lots of parts.
tthams
Yeh, but again you don't know what you are getting with the age of the tractor. Every Allis tractor that I watched my Dad buy over the years, always seem to have something hidden that was wrong with it.
For example my dad bought a 8070 and within a month ended up putting a new front end in it because the original was shot. 700 hours later and the tractor is doing great.
I think if I fix it, I know what I have then, otherwise I would again be taking a gamble. With everything fixed the tractor should last me for many years. It looks new already. |
