7060 INFO NEEDED
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: 7060 INFO NEEDED
    Posted: 04 Aug 2012 at 10:37pm
NEED INFO
 I HAVE A BLACK BELLY STANDARD SHIFT  7060 TRACTOR, THE DIPSTICK TUBE UNDER THE SEAT RUSTED THROUGH AND SOME TRASH AND PARTS OF THE RUSTED TUBE FELL INTO THE BOTTOM OF THE TRANS HOUSING. MY QUESTION IS, CAN I PULL THE RH FILTER CANISTER  OUT AND GET TO THE TRASH . I REALLY DON'T WANT TO TAKE THE CANISTER OUT IF I DON'T HAVE TO. I REMOVED THE LEFT HAND CANISTER AND HAD NO LUCK .  ANY HELP / INFO WOULD BE DEEPLY APPRECIATED .
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 11:02pm
You are looking in the wrong place. Remove the cab floor then remove the plate that covers the range trans. Not a good way to clean it out.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 2:51am
Thats s real bad situation with rust and junk, has it been sittin awhile?
Edited by DougG - 05 Aug 2012 at 8:35am
