7060 Hydraulics
ABDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ABDave Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Hydraulics
    Posted: 11 Apr 2020 at 12:11am
Is the hydraulic system on the 7060 open center or closed center?
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 5:18am
Closed center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ABDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 9:35pm
Thanks Brad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 9:46pm
I can't ever keep them two separated as to which is which. There's gotta be a simple explanation as to what makes each what. My 220 is one and my 8070 is the other. Are all closed system constant flow?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 9:58pm
Open center is constant flow. Like your 220.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 12:16am
Open Center like on the 190 or IH 1066 is constant flow, variable pressure. Closed Center like in a Deere 4440 is constant pressure, variable flow. An Allis 7060 has a PFC system, (Pressure and Flow Compensated) which is variable pressure and variable flow. Most modern tractors have what the old 7000 series started with in January 1973.
Wink
I am a Russian Bot
Mad jim macafee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mad jim macafee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 7:46am
So i geuss we didn't check anything on the hydraulic pump. Would that make a difference on whats wrong? And how do we check it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mad jim macafee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 8:16am
Sorry, wrong thread. Happy Easter though!
