7060 hydraulic issues |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1152 |
Topic: 7060 hydraulic issuesPosted: Yesterday at 7:06am |
I have a 7060 power shift that has no brakes, pto, 3point, hydraulics, and the steering works, but isn’t right. I bought the tractor with a bad engine, and just split it and coupled a front end on it off a tractor with a bad transmission. I pulled the screen and cleaned it and it was terrible before I put oil back in. Started it and it had brakes and 3 point I know at first. Picked up canister filters after I lost hydraulics and the right filter was backwards. Put new ones in and still nothing. Pressure gauge on the pto valve reads 1000psi sometimes when I start it and 3 point raises, but after that goes to almost nothing and won’t do anything. Any ideas? Piston pump?
Posted: Yesterday at 7:48am |
Not knowing your experience makes it kind of hard. AGCO hydraulic filters only (2) under the belly and installed the correct way. Left filter must have a screen in it to open the internal oil door. Remove top sight glass and oil level needs to be that full sitting level and engine off for 20 minutes. Power steering not good is lack of oil or a bad pump or a stuck priority spool. You don't describe exactly what the steering ain't doing right. Power steering all starts at the left hand filter and it must be n AGCO filter. Stand-by pressure 400-600 psi with hydraulics at rest. 2400-2500 psi when activated. Which screen was dirty ????????????????
DanielW
Posted: Yesterday at 7:56am |
There are other folks on here who know these systems better than me. But having just done a pile of similar diagnosis & repair work on a 7045 (and having learned a lot from helpful folks on these forums), I can comment with some knowledge:
As you probably already know, the 'hydraulic pump' on these tractors is actually three pumps coupled axially together. Going from the rear of the tractor (where they're driven from) to the front, you have: i) A geroter pump that pulls from the trans sump and puts trans fluid through the cooler, power-director (if a PD trans), and other tranny paraphernalia. ii) Coupled in front of that is a gear pump with flow divider, which pulls fluid from the rear axle sump (through the LH suction filter) and puts fluid through the power steering, cooler, second (RH) fluid (and into the surge chamber), and lubricating/cooling oil for the brakes and PTO clutch (note: COOLING and LUBE oil for the brakes/PTO clutch. Not the pressure to run the brakes and PTO clutch themselves - just the cooling/lube). iii) Coupled in front of that is a variable-displacement, pressure-compensated (closed-centre) piston pump. This runs the remotes, three-point, PTO, brakes, and diff lock. That's a bit over-simplified, but it gives the Coles-Notes version of everything. Now for your problem: A proper set of pressure gauges and checks is probably in order (which it sounds like you've started already). But because you periodically had brakes, three-point, and steering, I'm going to guess (/hope) that your pumps are whole and working in some capacity. It sounds like oil starvation problems, which are not uncommon on that series. The first thing to check is that you have lots of fluid in the rear end and (most importantly) the correct length filter in the LH housing. This was a well-known/common problem with these hydraulic systems. When installed, the filter 'should' be long enough to push the trap-door (called the 'anti-drain valve' in the manual) open and allow the LH filter cavity to fill. It doesn't push it open much - maybe 3/16" or so. A common problem was that these filters aren't all made the same. You really want to get the AGCO ones. The problem: All companies that make this size of filter make the metal filter-body length the same. But many manufacturers use different gaskets at either end. Most use thinner gaskets, and some use thin gaskets that also fit into a little recess in the end of the filter-body. The AGCO filters have much thicker gaskets adhered to the end of the filter body, making them about 1/8" longer than many/most other brands. If you use one of the other brands, they often aren't long enough to open the trap door and let the filter cavity fill (or rather, they only open it a smidge: They allow a little fluid to come through, but not enough to keep up with the flow demand and it will quickly/periodically starve for oil). Thus: A shorter or non-AGCO filter can cause hydraulic starving problems, resulting in intermittent or no hydraulics. Coupled with this (I learned this from a local old Allis mechanic) is a problem that can happen to the filter housing components if it's used with the wrong filter: There's a lot of surface area around the trap door and filter end caps. If it's been run with a slightly short filter, it can create enough suction/vacuum on this surface area to bend the end caps in a little, which further compounds the problem as it effectively shortens things even more. When you disassemble the components in the LH filter housing, it's critical to make sure the removable end caps and the bar that pushes the trap door are straight/square. It's also abolutely critical that the screen be installed in the end of the LH filter, as its thickness/length is required to open the trap door sufficiently. On my 7045 when I couldn't get an AGCO filter for the life of me, I got by for a little bit by making a second disc-shaped gasket our of some cork gasket maker to put in front of the filter and extend it a little, to make sure the trap door was opened sufficiently. I wouldn't want to run for a long period like this (when doing this, you're only relying on spring pressure to hold the filter against the gasket and keep everything in-place. It might last forever like this, but if anything ever went awry I wouldn't want it sucking the cork gasket into the pump). But worked dandy for a short test. I like my Allis's, but this design (and relying on gravity pressure to keep the filter filled) is not my favourite design. Because you're relying on gravity to force fluid through the LH filter, it's also critical that you have enough fluid in there AND a clean filter. When the filters started to get old/plugged they would cause similar problems, and some folks compensated by just over-filling the rear-end. This created a little more gravity pressure to help force fluid through the LH filter. So: First step (in my opinion) would be to ensure the LH filter is clean, has the screen on the end, and is the correct length/AGCO filter. At the same time, make sure all components of the filter (end cap, trap door pusher bar) are not bent in any way, to ensure that it's opening the trap door sufficiently far. Also make sure it's well topped up with enough fluid. After that, I would be suspect of the compensator and priority valves for the piston pump. It's not uncommon for them (not only on Allis's, but on any similar hydraulic system) to get some gunkulence in them and be sticky/jammed. It's fairly simple to take them apart, clean them up, polish the spools, and re-assemble with new o-rings. Take a look at this note and picture from the Allis manual. Note my sketches in red, which show how the T-Bar and end-cap can get bent over time (especially if the trap door hasn't been opening far enough and it's created a lot of suction pressure). ![]() Edited by DanielW - Yesterday at 8:00am |
7060
Posted: Yesterday at 8:01am |
The screen is in the left filter and they are new agco filters. The right filter the spring and plate was to the outside before I changed it. Dual speed pto shaft was robbed out when I got it and rag shoved in the hole so been setting without oil in it but everything looked clean in there when I dropped bottom plate to put the pto back together. The suction screen for the transmission pump was the one that looked bad. Hydraulic filters didn’t look bad though. Obviously the right one wasn’t doing anything. Has new oil in transmission and rear end up to sight glass. Steering acts like it’s got air in the line but pump doesn’t sound like it’s cavitating.
Edited by 7060 - Yesterday at 8:03am |
DanielW
Posted: Yesterday at 8:02am |
I should add to my last post: While I didn't have this problem myself, I read a few cases online about folks whose filter housings/o-rings weren't quite sealing correctly, and allowing it to suck air and cause similar problems. Make sure your o-ring on the cap that bolts the filter assembly in is straight and square with a good o-ring on it.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8809 |
Posted: Yesterday at 11:02am |
Double check your hose connectins/positions since you just did a swap. Some lines can get hooked up wrongand cause crazy issues.
DanielW
Posted: Yesterday at 12:14pm |
Hmm. While some more pressure tests are really the 'proper' next steps, if it were mine I'd start by disassembling, cleaning, and polishing the flow divider. Common problem for them to get stuck, causing the symptoms you describe. And they're easy to disassemble and clean with everything's still on the tractor. Take a look at this thread, where it's discussed in detail: |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2465 |
Thanks(1)
Posted: 20 hours 52 minutes ago at 8:17pm |
As others have said, the power steering is kind of separate from the other hydraulic functions. It uses a gear pump and all of the other hydraulics are maintained by the piston pump. Both of these pumps get their oil from a common sump and filter combination. As the steering goes, jack the front end up and disconnect the power steering hoses at the cylinder. You should be able to turn the front wheels by hand without much of any resistance. Obviously, there will initially be oil in the cylinder which will need to be pushed out. Have some pans or buckets available to catch the oil and prevent a mess. I've seen them binding in the spindles to the point that you would swear that a new pump was needed.
Edited by Lynn Marshall - 20 hours 51 minutes ago at 8:18pm |
Mikez
Posted: 19 hours 48 minutes ago at 9:21pm |
There also was a post that even agco filters gave trouble.
Thought that was an interesting post.
Posted: 19 hours 19 minutes ago at 9:50pm |
Please bring that post up. I don't remember AGCO hydraulic filters being a problem on a 7060 ......
7060
Posted: 9 hours 36 minutes ago at 7:33am |
I took the compensator out and seemed like it moved okay. I pulled it out with my finger. Cleaned it up and put it back in. Nothing still. Is there somewhere else I can test pressure to figure out what’s going on?
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8764 |
Posted: 9 hours 33 minutes ago at 7:36am |
I'm not sure how to bring that post up, but I do remember tbran posting about it, maybe 6 months ago???? Darrel |
Posted: 9 hours 16 minutes ago at 7:53am |
There are two compensator spools and springs. Either can cause issues if stuck or broken springs. If they are OK, I might think a broken swash plate spring inside the piston pump. But, if the power steering isn't up to par (cavitation or gear pump failure) it has an effect on the piston pump !! because it charges the piston pump. That's why I keep harping on the power steerings performance.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 691 |
Posted: 9 hours 12 minutes ago at 7:57am |
Sounds like the couoling between the first two pumps and the piston pump is stripped
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
DanielW
Posted: 8 hours 24 minutes ago at 8:45am |
Interesting. The last two filters I've bought from an Agco brand were for a Massey - bought about a month ago. They replaced ones I'd previously bought from the same Massey dealer for the same tractor. The old ones I bought from that dealer (I think 2 years ago) said "Agco" on them and had the Agco part number. The ones I just bought a month ago are labelled (if I remember right) "Agrifilter", and are slightly different outside geometry.
I wonder if at some point in the past year or two Agco has changed who they're sourcing filters from. I heard a while ago that the proper Agco filters for these hydraulic systems were made by Baldwin, and that Agco sourced/badged all their filters from Baldwin. Maybe Agco has now switched from using Baldwin filters to some other brand?
DanielW
Posted: 8 hours 19 minutes ago at 8:50am |
I also think that next time I change the L.H. filter in my 7045, I'll tack on some 1/8" flat-bar onto the face of the t-bar that pushes the trap-door open. It seems like there's lots of room to push more open, and that way no matter what filter I use, I'll know that it's opening sufficiently far.
Posted: 8 hours 16 minutes ago at 8:53am |
Just position a thick Oring between the screen and the filter itself. I've done that for 40+ years.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3590 |
Posted: 8 hours 2 minutes ago at 9:07am |
ALSO - there are screens in BOTH belly filters. 70269921 and 70269922 . In the past few years we have been adding an oring or pull the cork off the old filter and add to the new to help open the 'trap door'. We have not had an issue with oem filters, just want a little fudge factor on a 50 year old unit..
