7060 hydraulic fluid ? |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3582 |
Topic: 7060 hydraulic fluid ?Posted: 2 hours 47 minutes ago at 11:40am |
I’m replacing my 79’ black belly 7060’s plastic washer seals on its rear-end’s 3 drain plugs(1 differential & 2 finals). Plus inserted new rubber ring seals on its hydraulic lines that go into filter’s housings. These are the lines from pump.
Question: while adding new XL821, I mistakenly over-filled it(3 gal?). New oil is so clean it was difficult to see in glass site gauges. So I drained excess from left final plug because a 5 gal bucket fit there easiest. After draining left final by 3 gal, site gauges are still reading full? So wondering if I just started engine should rear fluid equalize between diff & finals? Which begs another question; does trans pump circulate fluid thru filters & then to each compartments (finals/diff?? ) or does fluid drain/run into finals from the one diff area? TIA |
Posted: 1 hour 58 minutes ago at 12:29pm |
I'd have left the 3 extra gallons in there. Just start the engine and let it run for 5 minutes or drive it around the yard and then let it sit for 15 minutes minimum.
