7060 exhaust manifold
dualquads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dualquads Quote  Post ReplyReply Direct Link To This Post Topic: 7060 exhaust manifold
    Posted: 08 May 2011 at 8:53pm
I have cracked center manifold on my 7060.  Tried today to get the bolts out with a socket and flex-handle.  Very tight to the point of afraid of breaking them.  Any tips on how to get these things loose?  Thought about using a heavy air impact wrench but it's at the other farm and I didn't have much time today.  Thank you for any help.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:20pm
Soak with favorite pentrant.Get a large drift/punch of some kind,set against the head and give it a good whack with a 3-4lb hammer.Your probably stuck at the bolt to manifold joint as much as anything. They only torque around 65ft/lb.
armandjones82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote armandjones82 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 5:07am
Originally posted by dualquads dualquads wrote:
I have cracked center exhaust manifold on my 7060.  Tried today to get the bolts out with a socket and flex-handle.  Very tight to the point of afraid of breaking them.  Any tips on how to get these things loose?  Thought about using a heavy air impact wrench but it's at the other farm and I didn't have much time today.  Thank you for any help.
A regular ratchet would not apply enough torque so I've used a breaker bar to get mine loose.. A loud pop type sound would come out when their already loose..
