7060 electric lift pump
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Topic: 7060 electric lift pump
    Posted: 16 Feb 2021 at 11:31am
IM looking for ideas on adding a electric lift pump and possibly the filter on my 7060. The hand primer pump (which is a constant source for leaking) is leaking profusely again after i replace the entire assembly about a year ago. Also don't want to get into replacing electric pumps regularly either.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 11:49am
Theres a few out there that would work good for that , Holley makes some 3- 5 lbs of output, those hand primers are aggrivating , Ebay has a good selection of good ones , so does your local auto parts store as they are very common now a days, it will be a nice addition
Dave974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave974 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 2:12pm
There was a recent thread on this topic in the Farm Equipment section:
Adding an electric pump to my 7080 definitely seemed to do it some good and the pump has been in place for about 250 hours without issues.  Longer-term reliability remains to be seen but so far, so good.
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2021 at 9:17am
Thanks for the info
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2021 at 8:26pm
Depending on how much "lift" you need sometimes the cheapy ones will work. I had minor frustrating air leak/loss of prime issues on several of my 70xx tractors and was able to get by with the cheap ones. If you go the Holley red route, which we have some of too, make sure you dont spill any fuel on it hooking it up, and that it doesnt get too hot or vibrate too much. The magnets are "glued" to the case and will come loose and short out. Had that happen on several that were on red combines.
