7060 Clutch Return Spring |
tractorman21 ![]() Bronze Level ![]() ![]() Joined: 17 Sep 2020 Location: Chesapeake, Va. Points: 29 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Mar 2022 at 9:17pm |
Hello,
The clutch pedal return spring broke in my 7060 while sitting over the winter. I ordered a new spring and for some reason I am not seeing where it hooks on the bottom of the floor/cab. Is there a piece that fell somewhere when the bottom part of the spring broke? I have tried looking for a diagram of how everything should work, but I am clearly overlooking something. Any thoughts or suggestions are greatly appreciated. |
It hooks straight forward from peddle. Remove left hood and lower side panel. There is a key that the spring hooks to through fire wall. MACK
Mattman ![]() Silver Level ![]() Joined: 20 Dec 2012 Location: Plover, WI Points: 231 |
Would you happen to have part number for spring?
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2375 |
#70272167 spring. You may need the link,#70272168,depending on the serial number. This is for a power shift.
Lynn, your response with part numbers is greatly appreciated!
