7060 broke the drawbar?
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: 7060 broke the drawbar?
    Posted: 30 Apr 2023 at 11:29pm
Well as the title says I broke the drawbar on it planting beans so I was wanting to confirm that a 7000 to a 8070 all have the same drawbar?
The Agco parts book has different part numbers for the 7060, 7080, and the 8070 but they look the same and other sites say they’ll all fit…
Is there a difference or not?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 11:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 5:49am
7000 will fit a 200 or 190 XT.    7010/8010 and up will fit your tractor. If the tractor has 540/1000 PTO there are two holes at the front to get the length correct for the PTO shaft. Generally, an 8050/8070 and bigger have a higher strength drawbar to allow for heavier drawbar loads. That break looks kind of fresh, so it was overloaded?? or is there a story to explain why it's broken ???
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 5:59am
8070 drawbar is slightly longer and only has 1 hole in the front because of the tractor being 1000 rpm pto.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:18am
OUCH !!! No way JBWeld will fix that ..Cry
curious.... was it factory 'machined' where the pin goes in ?
that's a LOT of metal to just 'break'......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:58am
West Allis metal is showing its age and fatique, heard of a few 180, and 190,s breaking around here
Tenn allis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 7:13am
Have broken several draw bars over time pulling large manure tanks and grain carts and even bent a few which were useless afterwards and the best way we figured out how to save a draw bar was to put a bolt or pin as close to the hitch pin hole as we could and then run a heavy chain behind that pin and then run the chain up over the 3 point arms and let the 3 point carry a large portion of the weight. The bouncing of the weight on the draw bar and flexing it was what was breaking them and by running a chain under the draw bar and sharing the weight with the lift arms it took the bounce out   After doing this we never broke another draw bar if they were adjusted right
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 8:10am
We have a 11-19” row bean planter that has the wheels on the front so it pulls up on the drawbar ( putting a chain around it and making the 3 point take some would make it worse) so the more weight in the boxes, the more it pulls up.
Here’s a fuzzy picture of the setup…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 8:16am
Thanks for correcting me Doc!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 8:36am
I got a BMB 15 FT brush hog and it sure makes the 6080 drawbar flex,,
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 11:21am
Dang, good reason to have a safety chain hooked up.  Eisenmann supply in Madison Ne will probably have a good used one if you want to drive that far.  I was there a couple months ago and they had a few 70XX Allis's parted out and I think the draw bar still in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 11:11pm
I got one from All States AG Parts for $267 ship to my door…
So I’ve got it on and fixed up already…
Thanks anyway
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 7:20am
Is it new or used
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 11:52am
Used
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 12:10pm
 Several years ago I bought a used D-10 series III it did not have a draw bar, someone gave me a red one, that's 3" short, not sure if how thick & wide it is supposed to be. I'm thinking about welding 3" to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 9:18pm
I don’t know if that would be a good idea, might be a better idea to trade with someone…
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 1:58am
i've seen them bent before...but never broken! whew!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 6:02am
IF I HAD to weld a drawbar, because I couldn't actually find a correct replacement, the drawbar would be turned around placing the welded area AHEAD of the support bail. It would probably also have extra steel added to the repair area, not just weld.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 11:24am
If you do weld it, make sure you bevel both sides.
Jig up both pieces.
Pre heat the metal.
Weld with a low hydrogen rod.
I like to use a needle scaler to chip the slag. This  peins the metal which helps relive internal stresses. (Do this while it is still hot)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 12:52pm
I agree with both of you, but only in desperation….
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 7:05am
I bought my first 6080 with a welded drawbar several years later I broke it further back bought an aftermarket one and bent it.   Running a salvage one now.   Took longer to break the welded one than bend the aftermarket one.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 7:12am
Jig up both pieces.
Pre heat the metal.
Good advice.
