7060 black belly steering issues
jmnuren View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmnuren Quote  Post ReplyReply Direct Link To This Post Topic: 7060 black belly steering issues
    Posted: 29 Oct 2024 at 8:19pm
Last couple years I would lose steering while turning left idling down, happened once every 50 hours. This year it started to act up you cannot steer left without turning right first. Steering wheel turns a little bit easier when it doesn’t steer the power steering works great when working. Oil levels are all up oils is clean probably 200 hours on it. All remotes work fine and three-point works fine.
John
UC,E,K,U,WC,WD-45,7050,
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 10:09pm
check your seals in the steering cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 6:28am
200 hrs on the hydraulic oil??  Were the TWO hydraulic filters changed at the same time??   and was the steering acting up at all prior to this oil (and maybe filterS) change ???  Where are you checking the hydraulic oil level ??
Edited by DrAllis - 30 Oct 2024 at 6:29am
This page was generated in 0.219 seconds.
