7060 alternator pulley |
Kevin210 ![]() Silver Level ![]() Joined: 08 Oct 2018 Location: Indiana Points: 430 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Jul 2019 at 8:00am |
Anyone have an alternator for a 7060 or
the double pulley for half inch belts. I hate to say it but please don't recommend All states ag parts as I have already called them 3-4 times about getting the pulley and have got no response from them. |
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
I may be wrong but don't the 7060, 7080, 7050, 7040, 7030 all use matched set of 5/8" belts? This is for both Delco and Niehoff alt's.
Pulley AC part #'s. Sorry but don't have the offset distances here. Delco alt. - 70267872. 3.5" OD x twin 5/8" groove, .670 bore no keyway. Niehoff - 70269548. 3.5" OD x twin 5/8" groove, .670" bore w/keyway. Any shop working on farm, construction equip. electrical parts should be able to get you a pulley that crosses to these numbers.
Thanks.
The reason I need the pulley to begin with is I have replaced the 3500 engine with a 3700 in my 210 and the 210 belts are different than the 7060 belts and pulleys. |
OK, the older AC's have used these sizes of 1/2" double pulleys. The biggest difference is the outset from alternator bearing, this helps aligns the belts. IF you have the original alt and mounts from 210 / 220 the first pulley may be what you need.
#70254832 on D19, 210, 220 not sure of Alt make. .670" bore, 3.25" diam. #70256332 on 200, delco DB series alt. .670" bore, 3.125" diam. #70260105 on 7000, not sure of alt. .670" bore, 3.5" diam. #70260105 on 7010, 7020, 8010. not sure of alt. .670" bore, 3.5" diam.
