7060 alternator problem |
ToddnwIl
Topic: 7060 alternator problemPosted: 13 Jan 2021 at 4:39pm |
Our 7060 had the neihoff alternator on it and we have changed it over to a delco 110 amp alternator. We are using the old pulley but the tachometer isnt reading right. What pulley do we need and where can we get it?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 13 Jan 2021 at 4:53pm |
betcha Steve wil know........ I'm thinking if it reads low now, you need a smaller pulley as that'd speedup the alternator. Course that begs the question HOW will you know that 1200 RPM IS 1200 RPM ?
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 13 Jan 2021 at 5:02pm |
If you are using the old pulley, I should be turning the same speed. There may be a difference in the number of pulses between the alternators.
Darrell G (MN)
Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
Posted: 13 Jan 2021 at 7:09pm |
I believe ( can't remember for sure, someone told me that when I was thinking of a Delco.) you need a pully from a 1206 int. and that should make your tack accurate
Ron(AB)
Posted: 13 Jan 2021 at 7:39pm |
Size doesn't matter. haha
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 13 Jan 2021 at 8:08pm |
I get mine from Sioux City. They are 3 7/8 outside diameter. I was thinking that Shoup offered them too??
Albert
Posted: 13 Jan 2021 at 8:56pm |
I can help with the correct pulley for the conversion and also the belt will line up better.
Albert
Michael V (NM)
Posted: 13 Jan 2021 at 10:10pm |
How did ya get the niehoff pulley on the Delco? The niehoff I have seen, the shaft is smaller than the Delco, I suppose it could be drilled....
Gregor
Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
Posted: 15 Jan 2021 at 10:16am |
I was wondering the same how you got the pulley to work. A year or so ago I changed out my 8030 to a delco and had to get a new pulley as the one it came with only had a single grove belt set up and the niehoff pulley would not work?
Posted: 15 Jan 2021 at 11:56am |
40+ years ago, A-C had a "kit" to update older Delcrotron alternators (old maroon 7000 series) to the new 100 Amp Neihoff. It came with a new tachometer. Must be the old tach wouldn't read correctly with the Neihoff.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 16 Jan 2021 at 9:53am |
Not only did some of the Niehoff's have a smaller .580 shaft, vs the .670 Delco shafts, the pulley diameter as well as the offset was a bit different also if memory serves me right. As Albert mentioned the belt fits better. Its been quite a while since I've changed over a Niehoff. They were a PIA sometimes when it came to tachometer outputs... Steve@B&B
Alvin M
Posted: 16 Jan 2021 at 10:17am |
I use Select Parts # 778-1069-1 it is the right to change from Niehoff to delco tack will work right niehoff pulley was 3 1/2 O.D delco is 3 7/8 O>D.O Shaft size is.670 For both
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 615 |
Posted: 16 Jan 2021 at 10:32am |
Hy Capacity has a pulley for this conversion.
