7050 turbo exhaust and intake manifold |
Tanman_2006 ![]() Orange Level ![]() Joined: 27 Apr 2014 Location: Fairview Oklaho Points: 275 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Jul 2014 at 7:19pm |
So I am buying a 4910 Hesston 4x4 big square and planning on tying it behind the Allis. It's been raining the past few days so I have done a lot of wire removal and cleaning up. None of the gauges work and I am tearing out the factory panel out in favor of custom gauges. (tiny tach, ect, egt, hyd psi, oil psi, oil temp, hyd temp, boost and whatever else you suggest.
In the process I found my turbo has a hole in the exhaust side, Crack in the manifold, and a blown intake gasket. What should I do to get this fixed? 7080 kit maybe? I see people saying to update the turbo but w/ what model? |
CIH 8930 MFWD Duals 205hp
9635 Massey Ferguson By Hesston Disk windrower 2856 Massey Ferguson By Hesston Round Baler 7050 AC PD Other tractors and GM Diesels |
Any advice on parts for my turbo issue?
GM Guy ![]() Orange Level ![]() Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
Have you checked the AGCO parts books website? IDK if the turbos are different or not.
If Sturgeons corner doesnt have what you need, Mike's should have it all. Mike also has a decent 7040 that he would sell running. because, after all, Tractors dont require tags, so they are cheaper to own in multiples. :) personally, I would keep the factory turbo, as with the full load/ no load the plunger gives, I would want quick boosting, but I have never pulled a ton baler (pulled small square....glad we dont do that anymore. :) ) so I may be thinking about it all wrong. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
critter ![]() Silver Level Access ![]() Joined: 13 Nov 2013 Location: Ohio Points: 254 |
There is something different with a 7080 turbo its not a direct bolt on, pretty sure you have to reroute the exhaust pipe/muffler. I am pretty sure you need a 7080 exhaust manifold too.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Over time I've found it's usually much easier, more economical and usually more functional to just stay as close to factory or factory replacement as much as possible. Just my small input as I used to get grand ideas like changing a D19 into something closer to 190 platform. Never did it but if I had I would have a devalued tractor that probably would have cost way more than just replacing the D19 with a 190.
Wink I am a Russian Bot |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5105 |
the 7080 turbo is a much different configuration. The 7030-7060 is an "on center" turbine housing. the 7080 has an offset turbine inlet much like most other common turbos. It can be made to fit, but requires all the 7080 components. The oil lines may work though with some tweaking. Just keep the original setup, since the 7080 turbo is still just a T04. There's lots better turbos to go with that would require fabrication, but end up with modern map ring technology.
I figured I need most of the required parts anyways so why not upgrade? My hood is junk so why not replace it too? There is also nothing I can do to devalue this tractor, it was saved from a scrapper.
I was thinking maybe a holset turbo, those are quick spooling but not sure of the size needed. I was going to use my 8930 size to base my guess off of. I am sure my current set up will pull a big baler just fine but if I can pull a big hill and bale w/ power to spare and get better fuel usage. |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22005 |
Exhaust manifolds are the same between 7050 and 7080. The hoods are the same except the 7050 has above hood air cleaner bowl. 7080 air cleaner assembly is larger and has automatic dust ejector. 7080 turbo exhaust elbow, diffuser, muffler, crossover air tube to intercooler and oil lines should work with newer Holset.
Thanks doc, now until I piece together a 7080 inner cooler kit or make my own I might run the hx w/ just the stock intake. What problems would I have here?
If the exhaust manifold is the same then I will try to get it welded up or something. |
7050 and 7080 both already have an intercooler/intake manifold on them. weld the exhaust manifold?? good luck.
That's odd, I don't think my tractor has an intercooler. Is it the typical ata cooler mounted in front of the radiator?
My turbo goes directly into the intake manifold. I'll take a better look I guess (could have over looked something) and some pics. I can't weld cast but my local machine shop can. If not I'll order a new one, it was worth the $20 to try. Edited by Tanman_2006 - 20 Jul 2014 at 9:10am |
"Intercooler"s are usually coolant filled for the heat removal of the pressurized turbo boosted air. "Aftercoolers" are usually air to air types ahead of the radiator using ambient air to do the cooling.
Ok, I am just used to my newer tractors that are all air to air, that explains why the intake seeps coolant out a couple bolts and is so stinking big.
richfarmsystem ![]() Silver Level ![]() ![]() Joined: 22 Jan 2012 Location: Ohio ill Points: 89 |
hope you do not intend to run a 4910 with a 7050 on any hills or plan on baling a lot of bales.
tornado8070 ![]() Orange Level ![]() Joined: 24 Mar 2013 Location: MI Points: 1341 |
Most guys with 4x4 hestons around here run them with 225+ HP. Level ground you may get away with it. Any hills and heavy material you may be in low gear. 4x4 balers take allot of power just from pulling the shear weight of the baler.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Sand mountains in irrigated hay, did it w/ a 190 Hesston for years before we bought 3 CIH magnums. I know they take power and I'm working on maybe a 7080 but I don't see any reason I can't run 200hp on the 7050 baling.
I'd like another Magnum but it's not in the cards at the moment. |
Be sure to glue the intercooler to cyl head gasket on both sides with a cement glue of some kind. Also recheck mtg bolts after a couple of days running before start-up in the morning when cold.
Would rtv work or does it need to be stronger? Do I need any seal on the bolts?
I glue gasket to manifold with yellow 3-M 8001 and let dry/get tacky. Then RTV gasket to the cyl head. Nothing on clean bolts as a rule.
Ok, I will try to find a glue that will work.
Any advice on torque specs (I know where to borrow a manual if needed)
