7050 rear end problems
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: 7050 rear end problems
    Posted: 10 Nov 2016 at 11:18am
My 7050 gets a hell of a shake when moving at slower speeds and some times it feels almost like its putting power to one axle and then over to the other axle kind of a wobbly feeling. I haven't drained any oil yet to look for shavings and dont want to drive it to fast incase something should lock up or let go. Any thoughts
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 11:46am
Is this with duals?
On a road or hard surface?
Bias tires?
Could just be tires not mounted straight on the hub center?
Also - cab isolators due for replacement...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 12:18pm
Sounds like a tire or lack of ballast issue to me. Engaging the diff lock would lock the wheels together to eliminate the side-to-side waddle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 12:47pm
Its done this for a while,years actually but not as bad as it is now. I always assumed it was the tires but idk for sure. First I had 23 degree radials full of fluid, then I put bias GY dyna torque tires also full of fluid. Currently it has a set of Armstrong bias tires no fluid. Duals or no duals,pavement or dirt it shakes and vibrates. This is all while just driving around not pulling anything. I never really noticed this while doing field work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 1:14pm
Try jacking one wheel up next time you have it in the shop, and turn the wheel a full turn to see if it runs true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 1:36pm
CAB MOUNTS....ADD AN EXTRA ONE ABOVE THE BATTERIES AND TWO EXTRA UNDER YOUR SEAT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 2:10pm
The two extra under the seat don't even need to be bolted in place....they just sit in a pocket and can't go anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 4:23pm
I'll give that a try,thanks
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 8:57pm
I agree with cab mounts, had a 7030 that way, new cab mounts fixed mine.
