7050 rear end problems |
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2372 |
Topic: 7050 rear end problemsPosted: 10 Nov 2016 at 11:18am |
My 7050 gets a hell of a shake when moving at slower speeds and some times it feels almost like its putting power to one axle and then over to the other axle kind of a wobbly feeling. I haven't drained any oil yet to look for shavings and dont want to drive it to fast incase something should lock up or let go. Any thoughts
Ron(AB)
Posted: 10 Nov 2016 at 11:46am |
Is this with duals?
On a road or hard surface? Bias tires? Could just be tires not mounted straight on the hub center? Also - cab isolators due for replacement... |
Posted: 10 Nov 2016 at 12:18pm |
Sounds like a tire or lack of ballast issue to me. Engaging the diff lock would lock the wheels together to eliminate the side-to-side waddle.
grinder220
Posted: 10 Nov 2016 at 12:47pm |
Its done this for a while,years actually but not as bad as it is now. I always assumed it was the tires but idk for sure. First I had 23 degree radials full of fluid, then I put bias GY dyna torque tires also full of fluid. Currently it has a set of Armstrong bias tires no fluid. Duals or no duals,pavement or dirt it shakes and vibrates. This is all while just driving around not pulling anything. I never really noticed this while doing field work.
Ron(AB)
Posted: 10 Nov 2016 at 1:14pm |
Try jacking one wheel up next time you have it in the shop, and turn the wheel a full turn to see if it runs true.
Posted: 10 Nov 2016 at 1:36pm |
CAB MOUNTS....ADD AN EXTRA ONE ABOVE THE BATTERIES AND TWO EXTRA UNDER YOUR SEAT.
Posted: 10 Nov 2016 at 2:10pm |
The two extra under the seat don't even need to be bolted in place....they just sit in a pocket and can't go anywhere.
grinder220
Posted: 10 Nov 2016 at 4:23pm |
I'll give that a try,thanks
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2317 |
Posted: 10 Nov 2016 at 8:57pm |
I agree with cab mounts, had a 7030 that way, new cab mounts fixed mine.
