7045 trouble
tnboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnboss Quote  Post ReplyReply Direct Link To This Post Topic: 7045 trouble
    Posted: 12 Jun 2016 at 12:40pm
Was cultivating with my 7045 p.s. shifted down to go through waterway didnt sound like it shifted right then just stopped. Lost all hydralics no power steering no lift arms or remotes. Hydraulic fluid and power shift oil both normal level. where to start looking? could it be the hydralic pump or worse? Its a nice 7045 repainted with new tires would hate this to be a fatal breakdown as one of my favorite tractors to use hoping not more expensive than the tractor worth. Any help would be appreciated. Thanks
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 12:47pm
Sounds like pump, happened to one of my 8070's. I think it cost around $4000 but I had some other stuff done to it to.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 1:09pm
Sounds like the torque limiter clutch disc on the flywheel ate her pigs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnboss Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 1:25pm
That sound expesive any idea what we would be talking if that is indeed the prognosis?
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 2:31pm
I think if you engage pto and it doesn't spin. (With tractor running) then you know it's the torque limiter. If it does then it's the hydraulic pump. Most likely its the torque limiter. If you are doing the work yourself I wouldn't think too bad of a price. Dr would know better. I would think there are plenty of good used ones around we always doubled the belvue washer when we had one split. And I think it was around 100.00 for that.
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 3:17pm
Had the torque limiter go out last year at 6000 hours on 7045. Hired work done need to split tractor, new limiter and some seals came in less than $2000.
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 7:00pm
Remove the third link bracket on the back of the tractor, dig out the cup/plug.  Start the tractor, is the shaft turning?  No, = torque limiter, yes = likely a different problem, up in the pumps.
Still in use:
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 10:39pm
Torque limiter. What ever you do, don't put any used parts in it. Resurface flywheel, new pressure plate, and new disc. Good time to replace rear main seal and ware ring.    MACK
This page was generated in 0.089 seconds.
