7045 fuel sending unit |
XT in pa ![]() Orange Level ![]() ![]() Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Feb 2012 at 8:09pm |
I got one from agco and can't get it to work. I think it hits the baffle in side the tank. I put it in the same direction as the old one came out. It only reads 1/2 tank all the time. I went by the directions to install it. Anyone else have done this ??? Shawn
190XT,D17and 7045
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21992 |
It is possible you might need to bend the wire arm a bit to prevent rubbing the side of the tank if that is the problem. Compare position of the float of the new to the old sender.
