7045 clutch brake
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Topic: 7045 clutch brake
    Posted: 01 Mar 2020 at 10:02pm
Bought this tractor with the clutch brake not stopping the tranny gears. Replaced cable, bushings and pin. Still an issue, wondering about the pressures and if it’s possible to replace brake with splitting the girl.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 8:24am
Could have some warped plates in PD.           MACK
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 9:21am
brake psi is 185 to 200.  brake can be replaced from bottom of trans after removing the hyd. pumps. the brake can't stop badly warped pd clutch plates.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 9:25pm
Worked on them for 50 years and never saw one warn out.        MACK
This page was generated in 0.083 seconds.
