7045 alternator
aaronac1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaronac1 Quote  Post ReplyReply Direct Link To This Post Topic: 7045 alternator
    Posted: 04 Apr 2024 at 7:21pm
Does anyone know the acdelco part number for a replacement altenator off of a 7045? Trying to find one at a local automotive store.
Wd-45 D-17s4 170 185 190xt 7045 8070
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 7:35pm
I use a 100 amp 10SI Delco . You need one with three small terminals for the tach to work. A wiring change is required and a larger pulley too, if you want the tach to read correctly.  I see that Shoup offers a complete assembly for sale.  Alternator, pulley, and small wiring adapter for that application.
Edited by Lynn Marshall - 04 Apr 2024 at 7:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 8:10pm
Someone asked this a month ago and  it seems like "MOST" of the Delco with the tach terminal are now 1 wire units.... Search of GOOGLE does not show much for the original 3 wire alternators with the extra "tach"..... but i did not look everywhere.
Edited by steve(ill) - 05 Apr 2024 at 1:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaronac1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 8:40pm
Im assuming that i can take off the old double pulley and simpley install it on the new one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 8:50pm
yes... the pulley are all interchangable on the BORE.. Its the diameter that is important
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 8:58pm
another option --- only 3 wire i saw...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 7:49am
That's a good price on that 3 wire. That's the way to fly. As Lynn mentioned it would need the larger pulley or use your pulley. Still utilizes the same .670 shaft.
Steve@B&B
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 12:21pm
Just curious: Where exactly does the "R" terminal tap into? Is it reading one phase or all of them?
This page was generated in 0.039 seconds.
