7040
mogle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mogle Quote  Post ReplyReply Direct Link To This Post Topic: 7040
    Posted: 07 Apr 2012 at 9:35pm
does any one know how to get to the scavenger pump on a 7040
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 10:08pm
If it has one, take the plate off bottom of torque tube just behind engine.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 5:34am
Why do you think you need to get at the scavenger pump??
Post Options Post Options   Thanks (0) Thanks(0)   Quote mogle Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 1:27pm
found alot of metal in the oil and has a lot of noise somewere in the hydrolics and cheacking to make sure all of the four pumps are good
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 3:16pm
A lot of metal in the rearend/hydraulic oil ???? or transmision oil??? where did you find the metal??
Post Options Post Options   Thanks (0) Thanks(0)   Quote mogle Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 11:39am
hydrolic oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 6:43pm
The hydraulic oil comes from the rearend. The Scavenge pump is in the front of the transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mogle Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 12:41pm
yes but all of the oil is shared
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 2:22pm
Actually Mogle, I am fairly certain that is not correct.  There is a trans dipstick in the front, in the cab, and a rear end sight gauge on the back left, and two different filters, and two different fill points.  I would have to go pull my hydraulic flow charts, but I think the scavenger pump charges the two pumps most rearward, and the front pump is the hydraulic pump, and only the hydraulic pump pulls from the rear, but again I have to get out the books
Still in use:
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 4:28pm
Oil is NOT shared!
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 7:34pm
Scavenger pump was used to return "scavenge" oil from power director clutches to the trans. housing. It was eliminated with the black belly pd tractors in favor of a gravity return system, I think early models could be updated. The gear pump charged the axial piston hyd. pump. hth, Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote mogle Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 6:57pm
o well it just seemed that it is shared because a pip comes from the gear geroter pump to were the scavenger pump is but yoo maybe right
