7040 torque limiter question
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: 7040 torque limiter question
    Posted: 16 Oct 2024 at 2:31pm
Can I replace a 7040 powershift 4 pad torque limiter with a 6 pad 12"? Is there any modifications necessary? I am looking to get more bite. I also plan on doing the extra washers. Any help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 3:44pm
You can, but six pads (of the same size) will slip easier than 4 pads.  From the school of hard knocks back in 1975.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 6:30pm
You can, but it shouldn't be necessary. If you're adding a second Bellville spring, slipping won't be a problem. I've done a couple of tractors where I had the machine shop mill the surfaces a little bit under the spec so that it made things tighter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 7:46am
Anyone know the agco # for the powershift torque limiter in an 76' 7040?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 8:03am
70268718V
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 8:05am
Thank you!
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 9:13am
This ^
More pads = bigger surface area = less overall pressure on the pads.  This is why high-HP car builds often go with "puck" type clutch discs over a traditional "full" disc, less surface area gives more bite for the same spring pressure hence a clutch that's not overly heavy but grabs a lot better. (and in the case of dry clutches, wears a lot sooner).
Not sure what the reason is for trying to gain bite, but if it's "mission critical" & you don't mind the prospect of reduced maintenance intervals I'd consider looking into having the puck material machined (either grooved or just area reduced).  Bearing in mind this comes from purely theoretical thinking & I have no experience of doing this, but seems a sound idea to me. YMMV
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 10:16am
I know we have been down this road before but for what its worth, yes there is less pressure per pad on a 6 but there is also 6 pads holding vs 4,  I have replaced dozens of torque limiters over the years and for me the 6 pad always require less slipping  on break in to get them to hold,  The heavy duty cummins conversion torque limiter from Hy-Capacity has 6 pads for a reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 11:02am
My premise is 6 pads versus 4 pads of the IDENTICAL size/shape/thickness and also with the exact same pressure plate squeeze.. The OP wants to tractor pull this unit and 3 pads will transmit more torque than 4 before slipping any.  4 pads will transmit more torque than 6.  I learned this a looooong time ago with a custom made tractor pulling button clutch. The disc had 6 or 8 pads on each side and that clutch wouldn't even move the sled. Disassembled and removed HALF of the pads and then the clutch worked acceptably. This advice was given to me by a veteran puller who said "more pads ?? you need waay more squeeze to get them to hold". He was right. I was wrong.
This page was generated in 0.178 seconds.
