7040 steering problem
ycattle1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ycattle1 Quote  Post ReplyReply Direct Link To This Post Topic: 7040 steering problem
    Posted: 17 Dec 2014 at 3:12pm
Bought a 7040 at auction and the powering steering lags. you turn the wheel and then the wheels will turn slowly. I this a power steering pump problem? New to the 7040 so not sure what I'm looking at.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2014 at 5:18pm
It don't have a p/s pump as such.It runs off one of the 3 hyd pumps but I don't remember which one.Someone will know what your problem is.DrAllis or MACK will know whats up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ycattle1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2014 at 6:30pm
Thanks, Steve M
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2014 at 7:29pm
Had a similar problem with a 7040 the priority valve was sticking had to clean it and it works fine now it's on the pump tward the front of the tractor has two plugs on it u can pull it out through the plugs and clean it
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2014 at 9:30pm
Check the left side filter to be sure that the screen is there. Also, jack the front end up, remove the steering hoses, and be sure that there isn't anything in the front spindle area that is binding on the power steering.
Edited by Lynn Marshall - 17 Dec 2014 at 9:31pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2014 at 9:41pm
The gear pump (middle) runs power steering. There is a plug on the middle pump that takes a 11/4 wrench. Remove nut, next a cap, spring, orffic plate(small flat washer with a small hole) then the spool valve. The spool may be stuck in housing. Get it out and polish it up.
 Check left filter in rearend housing. Screen may be missing or worst filter pluged with metal.
  Hope this helps. If not let us know.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ycattle1 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 1:21pm
Thank you for the info, I will pull it apart this weekend.
Thanks again
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2018 at 2:15am
what is suggested to polish the spool valve? I picked up a 7040 with sluggish steering that I need to correct.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2018 at 8:13am
My 7050, when I first bought it, turned like wrestling a bear. The right spindle had no grease zerk and I had to beat the spindle out with a 16# mall by first fighting to pull the axle from the tube and turning it upside down and putting back in tube, mine was just packed with dirt......... yada yada yada long story short, check that the spindle isn't stuck from lack of grease.
Edited by Lonn - 27 Jul 2018 at 8:13am
Wink
I am a Russian Bot
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2018 at 9:33am
I use 2000 grit, same as you would use for wet sanding paint.  Very important you must use it wet.  I usually sand things like that in the solvent tank.
This page was generated in 0.146 seconds.
