7040 power director transmission will not drive
Dock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dock Quote  Post ReplyReply Direct Link To This Post Topic: 7040 power director transmission will not drive
    Posted: 07 Jan 2025 at 5:14pm
I have a 7040 that pulled it out of shed this morning loaded feed wagon and it would not move again. It has been cold about 10deg this morning. Transmission oil pressure light is on at all rpms. Shift lever will freely go into all gears in both ranges with clutch pedal released. Both transmission and diff oil levels are good. I ordered a service manual but wondering if there could be something simple that I'm missing. Clutch spool sticking??? I don't know a whole lot about this transmission so kinda going in blind. Any advice would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 5:36pm
Power steering works ?? or not
Dock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dock Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 5:59pm
Yes, a little hard but oil had cooled before i tried it, I know the hydraulics work as well as the pto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 6:37pm
If the 1800 light is on all the time, either it is very low on oil on the cab dipstick or I'd guess the transmission gerotor pump has failed or its screen is plugged.
Dock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dock Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 6:52pm
Ok, thank you. The pump is the first in the stack (to the rear of the tractor) on the lower rh side of the machine? And the cover for the screen is on the bottom with 8 or 10 bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 9:13pm
Yes and yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 9:40pm
Welcome to the forum.
Goodluck
