7040 power directer
waltw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Topic: 7040 power directer
    Posted: 21 hours 33 minutes ago at 10:09am
    When first started it will not move in low.
      In first gear low range with high held down it will pull along but it takes a few minutes to for high to actually lock in, once it will fully ingage in high I can shift
To higher gears and it will and work in high but still want move in low.
      After 15 minutes or so it will start
Working in low . Will work normal the rest of day. I can apply brakes and load it down in low and high, clutches dont slip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 49 minutes ago at 4:53pm
Where exactly are you checking the oil for the transmission ??
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 59 minutes ago at 7:43pm
The transmission oil pressure light can be used to diagnose power director leakage, if it's working.
This page was generated in 0.107 seconds.
