7040 Overheating |
Post Reply |
Lakeville Orchards
Bronze Level Joined: 24 Jun 2019 Location: Williamson, NY Points: 2 |
Posted: 24 Jun 2019 at 7:15pm |
I have an AC that after 30-45 minutes of running will start to over heat. I have replaced the head gasket and have even put a different head on it. When it starts to overheat the anti freeze comes out the blow tube as a vaper, but no antifreeze is getting in the oil pan! Does anyone have any ideas?
MACK
I would start with a new radiator cap. Next check temp. with a heat sending gun. Clean radiator inside and out. Tighten fan belt and check pullies for ware along with belts. Check foam around radiator. MACK
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8143 |
Welcome to the forum
Orange Level Access Joined: 12 Sep 2009 Points: 19491 |
Starting by replacing the head gasket and cylinder was expensive, wasn't it ?? #1. Clean radiator INSIDE AND OUT and I know it isn't and I'm not even there looking at it. #2. Fan shroud must be there and in good unbroken condition. #3. Fan belts TIGHT and pulleys that aren't worn out. #4. New thermostats. #5. All the foam around the sides top and lower front on the radiator. #6. New radiator cap. #7. Do not overfill the radiator...there has to be some room for expansion or it will vomit every time it warms up. #8. New temp gauge and sender or a new manual type temp gauge. #9. Change head gasket or cracked cylinder head. #10. engine HP is set over the stock 135 HP it should be at. #11. Plugged muffler. #12. Leaking intake manifold gasket and low turbo boost causing the engine to make more heat than HP delivered. That's about it.
Post Reply | |
