7040 oil cooler leaks |
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Topic: 7040 oil cooler leaksPosted: 05 Jun 2014 at 1:05am |
hey all,
I also managed to get a 7040 going for this round of summer fallow, and hooked it to the smaller set of sweeps. It runs great and did a great job, had to trace an air leak into the fuel supply, but got that taken care of. anyways, it has an oil leak at the oil cooler. it is the seam between the rear elbow, and the body of the cooler. also getting slight weepage at the tiny hole. is there an o-ring that goes bad? gasket? or is it the cooler itself? if its the cooler itself, can a guy leave the housing and change the guts? (it has excellent paint, that is why I ask. :) ) otherwise, I am pretty happy with the old gal, it seems rather peppy and the straight pipe sounds great at 2200 RPM in 4th high under load. :) |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 05 Jun 2014 at 6:41am |
Replace the gaskets and O-rings in the cooler and you should be good to go. They get old and hard with age ,unlike me.
MACK
Posted: 05 Jun 2014 at 7:45am |
The elbo gaskets can be changed without removing the complete cooler. It would be a good time to remove the cooler and replace all 4 orings. MACK
Orangie
Posted: 05 Jun 2014 at 8:12am |
The O-R on the front water volute will need replaced too. I always shined the oil cooler tube up good with fine emery cloth. The oil cooler itself can be a little stubborn to tap out of the housing. Right or wrong, I use a block of wood to GENTLY tap out the cooler, then clean up the O-R grooves good. Make sure you install the O-R correctly, one is to the oil side, and one is to the water side. I use the wire wheel on the bench grinder to clean the O-R surface on the oil cooler itself, and lube up the O-R's when you put the cooler back in the housing. Have the other gsk's on hand to replace, the one in the cooler and the two that go between the cooler and block. Good luck!
7010, 7060, Two 8070's, Two R65's, 616H, and a few blue ones.
GM Guy
Posted: 05 Jun 2014 at 3:06pm |
"the O-R on the front water volute will need replaced too."
I assume this is at the front of the engine where it joins into the water pump housing? how often does this leak? alot of work to get that part of the housing off. :) |
Orangie
Posted: 05 Jun 2014 at 10:39pm |
I guess I always take the oil cooler off, in one piece. The two bolts on the rear elbow, and the bolts behind the oil filters, then the injection line clamp on top. It will come off in one piece then, and the O-R on the tube going up to the water pump volute can then be replaced. This O-R doesn't leak very often, but good practice to replace it. Be careful with the injection line clamp bolts, they like to weld themselves into the aluminum cooler, and twist off!
GM Guy
Posted: 11 Jun 2014 at 12:04am |
I re-read this post, and realized I wasnt very clear at all.
the oil cooler happens to be leaking engine oil, which is probably a whole different ballgame than if it was leaking coolant, correct? sorry gents! |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 11 Jun 2014 at 5:50am |
At the weep hole you can leak oil or water or both depending on which o-ring is leaking or if both are. The elbow gaskets I've only seen oil leak there. We have one right now that leaks at the elbow and I've got all the seals to completely remove cooler and replace them all. Including the o-rings on the tube going to pump. Which reminds me I have a question to post.
Wink I am a Russian Bot |
GM Guy
Posted: 14 Jun 2018 at 1:55am |
Well, the original 7040 in this thread finally started leaking worse, and I bought a new to me 7040 with the same issue, so its cooler re-seal time. :)
Looking at the parts book, http://agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79003880, page 46, is there a gasket to seal part #1 to part #18? They only list #15 as qty 1, so its not that. Currently the parts list is: 2 each of #8 and #11 #12 #15 #16 Is #13 necessary or can it be skipped? I imagine its a Murphys law deal, it will only leak if you spend the $ on replacing everything else... can a guy coat it in silicone? If a guy does replace it, anything need done to the piece the tube fits into? |
Lonn
Posted: 14 Jun 2018 at 6:39am |
Is #13 the o-rings on the tube? If so and if my memory is correct, they are super easy to replace while you are that far. I've been told by a mechanic for a big construction company in my area to put a little silicone on the o-rings for the core just before you slide it together. I've never done that myself but on the 7030 I did, the o-rings on the core leaked immediately afterwards, showing a drop of anti-freeze at that weep hole from time to time. Tractor is coming back into the shop anyhow to get the injector pump rebuilt this summer so I'll tackle that oil cooler again. I'll try the silicone but I think one should be careful not to plug that weep hole with silicone.
Edited by Lonn - 14 Jun 2018 at 6:39am |
Michael V (NM)
Posted: 14 Jun 2018 at 8:14am |
I just done this little project on my 7060,,, its not a big a job as it looks,, I think the worst part is having to drain the coolant and replace,, lol,, yes getting the cooler out of the housing can be a little tough, I just lubed the O-rings up real good and all went back together real neat,,,the new O-rings are all black,, so need to watch part numbers an get the right ones in the right place,, might try a search,,, I don't remember if I put pictures up or not...
LB0442
Posted: 14 Jun 2018 at 9:27am |
Here is a picture of the pieces. Like everyone said not a big job just have to ensure correct O rings go in the right spots.
GM Guy
Posted: 20 Jun 2018 at 1:04am |
The one gasket is "GASKET, elbow to housing (Eff. S/N 70-29018 & Up)" and the corresponding below SN 70-29018
Problem: all our 7040s engine SN's are 3D- instead of 70- They vary from 3D-34728 to 3D-43080. I assume subtitute 3D for 70, and since all are above 29018 order the newer gasket? |
Posted: 20 Jun 2018 at 7:09am |
The cooler core must be "timed" in the housing or it is pretty much ineffective in cooling the engine oil.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 20 Jun 2018 at 7:59am |
70- would be way newer than any 7040.
ACjack
Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 277 |
Posted: 20 Jun 2018 at 9:16am |
Please explain by "timed"? On my many visits to the assembly line I never noticed that ether one of the 2 assemblers who built up these cooler assemblies ever timed (indexed) the tube nest to the housing. They did use an assembly fixture that the rear elbow, cooler housing and front end cap with water tube were mount to for proper alignment while tightening the capscrews.
Posted: 20 Jun 2018 at 9:29am |
There is an "arrow" on one end of the cooler tube bundle and there is another arrow on the front (inside towards the eng block) of the housing. They need to be close to each other but not perfect. If that cooler core is assembled 180 degrees off, there essentially is little or no oil cooling.
ACjack
Posted: 20 Jun 2018 at 7:40pm |
OK good to know. Don't recall ever seeing an arrow on the tube nest (bundle) but, do seam to recall seeing a arrow cast on the cooler housing. Thanks again for refreshing my memory.
Michael V (NM)
Posted: 20 Jun 2018 at 7:52pm |
here ya go ACjack
may not be able to see in the picture, but theres an arrow on the little tag on the tubes
shameless dude
Posted: 20 Jun 2018 at 11:01pm |
I see Michael has a BIG picture window behind his tool box in his shop to look out of! nice! lol
GM Guy
Posted: 08 Aug 2018 at 1:55pm |
Also,
I forgot to ask, if its just seeping a little oil at the connection of the rear elbow and the cooler, can a guy get away with just replacing that gasket? Everything else is dry on that particular unit. |
Lonn
Posted: 09 Aug 2018 at 6:21am |
LB0442
Posted: 09 Aug 2018 at 9:14am |
The gasket is for coolant flow through the elbow into the cooler. If it is leaking oil the O ring would be the culprit.
