7040 low power issue
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 8:11am
You have to be careful adjusting on the advance
Allisguy93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 11:42am
So currently I have the pump tore back off the tractor after going threw all the fuel system again , inlet and return side , checking timing over and over again and making sure I don’t have slack in my gear train , I’ve talked with the guy who went threw the pump he told me to mess the the advance on it , that was to no avail , he’s does not have a test stand apparently to run it on. All he did was tear it down clean it and reseal and assembled it. I was under the impression he could flow check but obviously that wasn’t the case so after talking with a guy who knows the ac tractors more than me and has has several pumps gone threw by Dave’s diesel out of Muncie Indiana , I took the pump off and to them and they can tear it down and flow check it the whole 9 yards.   Suspicious that the cam is in backwards. Time will tell and I’ll post my findings. Thanks to all who commented to help me on this
This page was generated in 0.157 seconds.
