7040 hydraulic oil leak |
jazzsuds ![]() Bronze Level ![]() ![]() Joined: 21 May 2010 Location: AZ Points: 92 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Jun 2024 at 7:18pm |
I have a 7040 and when I shut it off it starts a fluid leak out of the hydraulics. What causes that and how do I fix it.
Thanks |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78809 |
its pushing hydraulic fluid out of the tank ?? ......... Vent plugged ? ... sounds like your building up pressure inside.
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 948 |
Do you mean the couplers are leaking?
You can get new ones. |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Not out of the couples but somewhere in the rear underside
There is a few steel lines that have a square o-ring on the end where they attach to the trans housing or anything around the hyd pumps could be leaking too.
You just have to track it down...wash the tractor and see where it leaks. |
