7040 hydraulic oil leak
jazzsuds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Topic: 7040 hydraulic oil leak
    Posted: 26 Jun 2024 at 7:18pm
I have a 7040 and when I shut it off it starts a fluid leak out of the hydraulics. What causes that and how do I fix it.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 8:09pm
its pushing hydraulic fluid out of the tank ?? ......... Vent plugged ? ... sounds like your building up pressure inside.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 12:30am
Do you mean the couplers are leaking?
You can get new ones.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2024 at 3:53pm
Not out of the couples but somewhere in the rear underside
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2024 at 12:39am
There is a few steel lines that have a square o-ring on the end where they attach to the trans housing or anything around the hyd pumps could be leaking too.
You just have to track it down...wash the tractor and see where it leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 11:55pm
Thanks I will look
