7040 engine oil cooler reseal |
DIESEL
Joined: 26 Aug 2013 Location: Sandhills Points: 259 |
Topic: 7040 engine oil cooler resealPosted: 28 Nov 2023 at 2:01am |
Oil cooler on my 7040 needs re-sealed, can the inner tubes be tapped out with a block of wood without damaging them, I don't have a press. First time messing with one of these, thanks.
Posted: 28 Nov 2023 at 2:48am |
Yes. We always had a 4 x 4 block re-shaped to slide in and be the pusher against the cooler core.
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1590 |
Posted: 28 Nov 2023 at 6:22pm |
Doc what all is needed as far as parts to complete this job?
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2427 |
Posted: 28 Nov 2023 at 6:55pm |
O rings and gaskets. Not much involved here. The cooler o rings are specific as to water side or oil side of the cooler.
Michael V (NM)
Posted: 28 Nov 2023 at 8:10pm |
I done this on my 7060 few years back. a search of my stuff might bring it up
I think the main thing is to put the o-rings in the right place
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 28 Nov 2023 at 8:32pm |
the block and cooler mating surface must be squeaky clean with a non silicone gasket sealer. That is the biggest challenge we have had.
I M Fedup
Joined: 01 Jul 2020 Location: Winchester Ky Points: 28 |
Posted: 28 Nov 2023 at 9:50pm |
Assemble everything loosely, and don't tighten any bolts until it's all together on the engine. Then tighten them down a little at a time, working your way around from gasket to gasket.
DIESEL
Posted: 04 Dec 2023 at 9:13pm |
Is it better to glue the gasket to the engine block or the cooler, on reassembly? Thanks
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 05 Dec 2023 at 8:06am |
Don't know about better...I glued gasket to cooler
DIESEL
Posted: 05 Dec 2023 at 12:16pm |
Thanks Steve, that's what I was leaning towards,Tbran mentioned having difficulty with this seal leaking, I didn't know if one was better than the other
SteveM C/IL
Posted: 05 Dec 2023 at 7:39pm |
I figured it may be harder to seal the slick aluminum over the cast iron block so I put the sealer there.
