7040 clutch trouble
brassring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brassring Quote  Post ReplyReply Direct Link To This Post Topic: 7040 clutch trouble
    Posted: 18 Apr 2010 at 10:04pm
today I was spraying with my 7040 PS. I pushed the clutch in and something popped and the pedal went to the floor, I checked everything over and figured it was in the valve body, was about to pull it back to the farm and decided to pull up on the pedal, put it in gear and away we went! seems something on the clutch arm sheered or broke, have a tarp strap on it now to pull it back up. it acts like a return spring broke but the spring is good, it seems to be slipping on the pivot shaft. anyone know what is wrong and what will it take to get the shaft out.TIA  Bob
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 1:40pm
when that happen you clutch cable is broke. that is what activate the valve. HTH
ryan
ryan
