7040 Alternator light flashing
jah72577 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jah72577 Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Alternator light flashing
    Posted: 07 May 2011 at 7:57pm
I just bought a 1975 7040 with power director after I started using it the alternator or "Gen" light started flickering. Sometimes I can hear a faint click from behind the dash when it does it too. It progressively got more frequent and then  my batteries were dead when I when to start it. So today got a new alternator and put it in. Got it running and everything seemed fine, no flickering light and the batteries were charging up. Untill a couple hours later it started flickering again! It tends to flicker more often and more brightly when the engine is running fast. Any ideas? I need some advice.
Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 10:17pm
Bad connection in wiring. Is the new alt still charging?  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jah72577 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:55am
I guess its charging, the batteries where not dead when I was donw. How would I know? Which wire?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jah72577 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 3:00am
Found out the batteries are draining overnite while it is sitting.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 6:11am
New alt may be bad. Hook a volt gauge to the big post on back of alt, should show 13.5+ volts running.  MACK
