7040 air in fuel system
INAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Topic: 7040 air in fuel system
    Posted: 14 hours 46 minutes ago at 3:01pm
7040 used about once a week or so to load round bales, today lost power lots of smoke, could see air bubbles in fuel filter. Turned off hand primed bled air cracked injector ran great 10-15 minutes and repeat. Pulled this 3 times but got hay loaded, shut down repeat everything fine for short time. Final time hand primer didn't seem to wanna prime, could this be bad and allowing air into system?? If not the cause, im at a loss. Any help? TIA
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 34 minutes ago at 6:13pm
That’s where I would stert
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 33 minutes ago at 6:14pm
sounds to me like a fuel flow restriction from the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 23 minutes ago at 6:24pm
Early 7040's had a plastic fuel supply line from the fuel filter base rearwards to under the cab floor to on top of the main fuel tank. The engineers made the injection pump draw fuel up thru a standpipe. It was a bad idea and oftentimes caused problems like this. Their fix was to go with a larger (than the plastic line) diameter rubber hose from the fuel filter base down and under the tractors belly and tap into the main fuel tank via the cross over hose between the tanks. This bottom draw system was what was needed and all the way thru the mighty 8000 series, that is the way they were. So, if you have the standpipe system, now'd be a good time to just eliminate it and convert to a home made bottom draw design. If you currently have a bottom draw system, disconnect the rubber supply hose at the filter base and hold it down below the fuel tank bottom and see if it GUSHES fuel out the end. It should. If it doesn't, you have a blockage at the outlet of the tank. By the way, if the hand primer squirts fuel all over when you pump it, it's junk.
Edited by DrAllis - 11 hours 23 minutes ago at 6:24pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 60 minutes ago at 9:47pm
If it does have the gravity flow system,  then the hose from the tank should have an adapter and elbow at the filter base. They have been known to plug with debris at that area. May need nothing more than a fuel filter change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 56 minutes ago at 9:51pm
New fuel filter about 6 weeks ago but haven't ruled it out. Tank about 3/4 fuel. Will continue to check lines thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 54 minutes ago at 9:53pm
Runs perfect for an amount of time, you can literally watch air bubbles form in the filter until it smokes horrendously
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 32 minutes ago at 10:15pm
I have a diesel tractor doing exactly that, I need to pull the tank and clean the gunk out; pulling the sediment bulb and poking a wire up through the wire was insufficient but it did make it able to drive it back to the shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 35 minutes ago at 11:12pm
Check the flow from the disconnected hose FIRST. If OK, then move on to the filter base connections/base inlet being plugged. Then, the filter itself.
