7030?? |
| Author | ||
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Topic: 7030??Posted: 26 Mar 2020 at 1:26pm |
Anyone see anything odd about this photo?
| Sponsored Links | ||
Posted: 26 Mar 2020 at 1:35pm |
Hood decals too high and crooked. Grille emblem too low. Engine oil cooler the newer aluminum housing instead of cast iron. Acousta cab #2 with flat front. Radial tire on left front.
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2735 |
Posted: 26 Mar 2020 at 3:26pm |
Orange axles (should be black)
Two lights in the center top of the cab (wth?) It looks lonely and in need of a good home...
AC7060IL
Posted: 26 Mar 2020 at 3:40pm |
Yes DrAllis & Brian F(IL). It was advertised as SN: 70301763 ?
Edited by AC7060IL - 26 Mar 2020 at 3:42pm |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 26 Mar 2020 at 5:49pm |
So is your "sluicing" a good or bad thing?? Do the descrepincies in the add make it a game-changer?? Just asking.
Posted: 26 Mar 2020 at 8:34pm |
It either never had a cab to begin with and sometime after the Fall of 1977 they bought a new current production cab, or the tractor had a factory cab and it got rolled over sometime after Fall of 1977 and the cab was replaced with the current production cab.
FREEDGUY
Posted: 26 Mar 2020 at 8:43pm |
Thank you, thought maybe a previous owner might have done some "shade tree" upgrades for the better. Lipstick on a pig is probably the better scenario
NE GA Allis
Posted: 26 Mar 2020 at 8:48pm |
Actually looks like the left side hood decal is on the right, besides being high. Edited by NE GA Allis - 26 Mar 2020 at 8:49pm |
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s, 1 WD45, 3 D15D’s, 1 D17 |
AC7060IL
Posted: 26 Mar 2020 at 8:50pm |
DrAllis, which models received the cast housing oil coolers? Which models received the aluminum oil cooler housing?
AC7060IL
Posted: 26 Mar 2020 at 9:00pm |
Good catch on the backward decal. |
Posted: 26 Mar 2020 at 9:01pm |
Early 7030/7050's had cast iron oil coolers that were square like a box. Aluminum came later on and was cheaper to make I suspect.
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1595 |
Posted: 27 Mar 2020 at 6:30am |
No batteries
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 27 Mar 2020 at 6:50am |
Wink I am a Russian Bot |
FREEDGUY
Posted: 27 Mar 2020 at 5:32pm |
"detective/ investigation", you did take grammar/english classes in middle school??
Lonn
Posted: 27 Mar 2020 at 6:18pm |
![]() Edited by Lonn - 27 Mar 2020 at 6:33pm |
Red Bank
Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
Posted: 27 Mar 2020 at 10:19pm |
I am not an English major but I thought the correct term should be sleuthing?
Lonn
Posted: 28 Mar 2020 at 8:42am |
Sluicing has a meaning therefore the statement FREEDGUY typed could be considered almost coded. Sluicing means making a statement without stating all the words but the statement would still be understood. A simple example would be .... Fred can repair a carburetor, not Dennis..... It's assumed that Dennis cannot repair a carburetor without the statement being completed. That is sluicing.
Also sluice or sluiced means wash or washed. Had to look that one up.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12425 |
Posted: 28 Mar 2020 at 11:07am |
I’d also think sleuthing is a much better fit, but??? Dang freedguy, don’t you hate it when you try and play grammar smartass and autocorrect makes you look dumb?😂
FREEDGUY
Posted: 28 Mar 2020 at 6:25pm |
Nope, apparently had Gold Rush on my mind. At least my spelling was correct. More than I can say for some
