7030 wont move
allis1984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Topic: 7030 wont move
    Posted: 04 Feb 2011 at 2:59pm
our 7030 wont move. pressure light stays on. Any ideas its go oil in. worked fine yesterday.  Thanks
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:23pm
Does the steering work??   If the steering doesnt work Id say the center went out of the torque limited, you might hear a rattle at the center of the tractor.  If steering does work, check the oil level in the trans, dipstick under the seat, if its got oil, the let the clutch pedal out in gear and push the high button on the floor down, if it goes into high then low is bad.  the pressure lite is telling you there might not be enough pressure to run the trans, very few times does the trans pump go bad, it usually somthing esle.  If it wont go in low, wont go in high, steers ok it may be the clutch hub splines bad on the input shaft, but the pressure lite shouldnt be on.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:34pm
ya steers fine. No high low. no gear clash if i try to shift with clutch engaged. So im stumped
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 5:06pm
Splines are gone/stripped on the low range PD clutch housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 5:15pm
with the splines striped wouldnt it build pressure or not?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 5:29pm
Hydraulically the clutch is engaged when the pedal is up.....only thing is the clutch isn't turning because the splines are gone. I'm not there but, if your steering works and you can't grind any gears with the clutch pedal up, that's what it is.
bena18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bena18 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 5:40pm
Might check suction screen on gerotor pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1984 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 7:37pm
ya thats what i was thinking if the screen i plugged. I know the splines arent striped out
This page was generated in 0.134 seconds.
