7030 weight.
Message Reverse Sort Order
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Topic: 7030 weight.
    Posted: 21 Dec 2010 at 7:07am
My book says 11700lbs.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 10:55pm
I have a 7060 cab 18.4-38s loaded, two weights on each side, full rack on front, 14L-16.1 fronts. It weighs 17100. Fluid is 1420 per tire, weights are 500 (1000 per side), and front rack is 1000.
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 10:43pm
What would a 7030 tractor weight with no weight, has  cab, and no fluid on 18.4x38s. Is is a little under 12,000 ? I have a hot shot truck that could haul it pretty cheap. I dont want to load on my truck and go by the scale to see. Just trying to save some time.
Thanks in advanced, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
