7030 Timing Issue
keppy32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Topic: 7030 Timing Issue
    Posted: 15 Aug 2025 at 7:49pm
7030 - unable to get it to start. Rebuilt injection pump, rebuilt engine, new starter, new batteries. The engine doesn’t appear to be the original. I attached a picture of the tag off the engine. We tried timing at 24 degrees, but all it does is smoke. The engine says 1-31-1979, so guessing this isn’t the original. Wondering what we need to do to get it fire. Thank you!
Edited by keppy32 - 15 Aug 2025 at 7:51pm
Sids View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sids Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 8:36pm
You sure it is not 1/2 off on the time. Line up marks in the pump, take drive gear off and turn   crankshaft one round, install gear and try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 8:37pm
We did try that, hardly any smoke then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 8:46pm
Whomever did the pump has to tell you what to time it at. A 7030 pump is 24 degrees BTDC. BUT, if it has been updated to 7040 timing advance it is 16 degrees BTDC. FIGURE IT OUT or you will ruin the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 12:33pm
That would have the rubber ring balancer so timing marks could have slipped and be incorrect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 4:36pm
Another perfectly good reason to align the pumps timing marks BEFORE removal so you KNOW where the running engine was timed at to begin with !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 4:47pm
We came here looking for help. If we knew what kind of remarks we would get, I wouldn’t have bothered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 4:53pm
You've been given damn good help. The rubber mounted crank pulley can slip and cause you the installer timing issues because the numbers are wrong. The pumps static timing numbers are also different between engine models (you said it has a different engine) and depending on what repairs have been done to it over the years. Incorrect timing can and will burn the piston bowls, so getting it right is indeed important. Your feelings are hurt over this ??? You've got everything you need to know right here and you're not taking advantage of it??  There will be hundreds of people who read this post and some will make a mental note of always aligning the pumps timing marks before pump removal to eliminate start-up timing issues. We all learn from this website. Good luck.
Edited by DrAllis - 16 Aug 2025 at 5:03pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 7:18pm
Wow! Great advice from everyone and no negative comments and that is the thanks you get! Maybe doesn't understand that there are a lot of variables on a 40 year old tractor.
Post Options Post Options   Thanks (1) Thanks(1)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 8:10pm
I do appreciate the responses, but some of your previous notes didn’t come across to me as confidence building. I’m sorry. We haven’t much luck getting anything to work like it should lately. This tractor is just another thing in a long line of problems. The engine is dated 1-31-79, the tractor serial is 70301993, which means the tractor was built in 1973. All we really want to is if that engine should really be for a 7030, or if it’s for some other model. If we know that if it’s for like a 7040, the timing has to be different. We replaced the crankshaft pulley, so it shouldn’t have shifted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 8:21pm
Thank you for the clarification. Yes fixing can be frustrating! Smile  Yes your tractor is 1973. But I have no idea of the engine serial number. That seems very difficult to track as noted on some previous discussions here.
Edited by Ed (Ont) - 16 Aug 2025 at 8:27pm
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 10:10pm
You mention rebuilding most everything except the injectors. I would assume they went in with the pump, but it isn't stated. Low pop pressures can cause your spray pattern to suffer. And I would listen to DrAllis about the pump shop knowing what timing advance is in the pump and using that to set timing. Beyond that I would say back to basics, do a compression check, check cranking speed. It should be good, but right now it is unknown. Make a checklist, and go through it, not just thinking it should be good because it has been rebuilt but verify that it is good. Something isn't quite right and nobody else on this forum was there when it went together, so all any of us can do is toss out suggestions, with some members having seen many more failures and their causes than the rest of us. I hope you get it figured out.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 10:14pm
It runs tonight. Appears to be a 7040 engine in a 7030 unit. Set it to 16 degrees & it took right off.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 5:49am
And that advice was given to you before you spouted off with “ We came here looking for help. If we knew what kind of remarks we would get, I wouldn’t have bothered.” You were given great help, no one else’s fault you couldn’t comprehend it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 7:59am
I guess being told to just ‘figure it out’ doesn’t come across as helpful when you’re already frustrated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 8:39am
The way it was timed, it should have started with a whiff or two of ether. However, continued use at that 24 degree setting ( instead of 16) would have eventually burned the piston bowls, ruining your fresh OH. That is why it was imperative to figure it out. Which engine, which injection pump, what updates the inj pump has gotten over the years, all of these things make a difference to timing. It's very difficult to offer the most accurate advice when pieces to the puzzle aren't known. I'm glad you got it running.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 10:25am
I am stating this as kindly as can possibly be done in written form via the internet, to wit:
You gave us a misleading title and also left out some vital information. It is indeed almighty difficult to troubleshoot from long distance, and nigh unto impossible when critical facts are distorted.
Glad you got it figured out Smile
This page was generated in 0.127 seconds.
