7030 shift/clutch trouble |
Simona5
Joined: 22 Feb 2016 Location: Lonsdale, MN Points: 5 |
Topic: 7030 shift/clutch troublePosted: 22 Mar 2024 at 8:51pm |
Hi, I have a 7030 power director. It won't go into gear when I start it in the cold. If I leave it in the heated shop or leave it outside in the summer, it will go into gear like it should. Length of time sitting doesnt seem to matter, just temp. I can shut it off, put it in gear, start it, and go. After running it a while, it will work properly but I want it to work properly right away. Is there a bad seal in clutch valve? I would love to get pointed in the right direction so I can fix it. Thank you
plummerscarin
Posted: 22 Mar 2024 at 9:40pm |
First thing I'd check is clutch cable adjustment
KJCHRIS
Posted: 24 Mar 2024 at 12:05am |
Which shift, 5 spd or Hi/Lo Ranges or the hi/lo PD floor buttons?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8866 |
Posted: 24 Mar 2024 at 12:16am |
X2
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 703 |
Posted: 24 Mar 2024 at 8:17am |
Ive never had a power director in the 7 or 8000 series
All mine have been power shifts but i think the same principle applies to both. Theres a procedure in the service manual to adjust the trans brake. I start at the beginning and do every step. They work flawlessly |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
bigal121892
Posted: 24 Mar 2024 at 8:20am |
One important thing to remember, once the transmission brake has been properly adjusted, it use to stop the transmission, not the whole tractor. Always bring the tractor to a complete stop, before engaging the transmission brake.
Simona5
Posted: 24 Mar 2024 at 12:31pm |
It does it with both shifters but not the floor shifter. I will look in the book on the adjustment. I was just thinking it was weird to only do it when its cold temperatures. I never stop the tractor with the trans brake. Kinda came out of nowhere. Thanks for the replies, I appreciate it!
SteveM C/IL
Posted: 24 Mar 2024 at 12:43pm |
They always work better when warmed up. Still it should work cold. You are probably on the verge with adjustment.
nanuk
Joined: 22 Aug 2013 Location: Saskatchewan Points: 258 |
Posted: 17 Jul 2024 at 2:58pm |
I have the operators manual
But not the service manual Anyone have a link to one for the 7060 pre 2000 serial#? I would sure like to be able to shift from a stop without grinding all the time |
AC7060Pd 1975
Posted: 17 Jul 2024 at 7:43pm |
What TRANSMISSION do you have ?? This issue has been discussed many times on this site. Probably the clutch cable or linkage adjustment if it is a POWER DIRECTOR transmission.
nanuk
Posted: 18 Jul 2024 at 7:12am |
Hey Doc
1975 7060 with 20sp PD I have recently had issues with the cable end on the transmission side being worn out and coming apart, but the problem preceded that. I replaced temporarily with an aftermarket end I will upgrade to the fully enclosed ball socket with through bolt if I can (newer?) I have one that fits, but makes the cable too long I will shorten it and try it again I have the cable as short as I dare and pulled as far forward as the slots will allow, and still the transmission is spinning I cannot at the moment reach the pedal end of the cable to shorten there If it is more shortening of the cable, then I will measure my new end to the original and shorten it to that The other option is to fight the pedal and shorten that end as much as I can. That’ll give me play to adjust better at the transmission end. |
AC7060Pd 1975
Posted: 18 Jul 2024 at 7:25am |
There cannot be ANY freeplay in the clutch pedal with the engine OFF !!! Get the correct parts and get that cable/linkage adjusted properly !! Replace the two bushings on the fork down low because one of them is always BROKEN. Spray WD40 on everything.
nanuk
Posted: 18 Jul 2024 at 7:48am |
Bushings on the fork
I assume this is the unit that the cable end connects to, that pivots on the ‘J’ rod and into the hydraulic piston What I can see in the parts schematic, i think I know what bushings you are referring to. I did notice there is some skew play on that unit Looks like I have a scavenger hunt coming. I am not sure my local dealer can source those parts anymore. There is about an inch of pedal travel before any resistance is felt (engine off) |
AC7060Pd 1975
Posted: 18 Jul 2024 at 7:50am |
ANY FREEPLAY gives you what you've got.............no transmission brake.
nanuk
Posted: 18 Jul 2024 at 7:59am |
Thanks Doc
I think I know what I need to work on I just hope I can get the parts to rebuild it. |
AC7060Pd 1975
nanuk
Posted: 18 Jul 2024 at 9:43am |
Well, another stumbling block
None of those parts appear to be available in Canada (possibly one bushing was located…. Possibly) |
AC7060Pd 1975
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 791 |
Posted: 20 Jul 2024 at 10:02am |
70269529 is the bushing I believe Doc is refering to. Shows a bunch in stock in the warehouse in Batavia.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
dchilton
Posted: 18 Sep 2025 at 11:27pm |
First thing I would look at would be HYD OIL if it is milkie it has water in it the fuild it has to warm up before it move because water froze. If you keep starting it let it warm up the limit slip disc will go out. You have spit the tractor to fix it 7030 bad about water in hyds.
Posted: 19 Sep 2025 at 7:25am |
Water in the transmission fluid (not hydraulic fluid) on 7000 series tractors with a cab is caused by a loose trans dipstick tube in the cab. This is from toolboxes and tools being carried on the cab floor banging against the tube, loosening it up. Not a common issue but can sometimes be an issue. Water in the transmission fluid has nothing to do with the torque limiter on the flywheel. 7030 bad about water in trans or hydraulics ?? Not in my books.
