7020 topshaft bearing
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 topshaft bearing
    Posted: 13 Nov 2024 at 7:10pm
The bearing on the top shaft behind the top link bracket is out. Will the shaft pull out the back or at least can I pull the bearing and replace it from the back? Will the coupler in front fall?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 9:24pm
Should be able to slide hammer it out the back without any issue. Make sure to get all the debris out by removing the lower plate above the drawbar.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 8:48pm
There is a timken bearing on each side of that top gear, im guessing if the rear one is out the other one isnt pretty, you would need to remove the rockshaft housing to replace them both, the coupler up front should be fine, its inside of the top range shaft and can't fall down,
It is really strange that this bearing is out, have never heard of that problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2024 at 6:24am
28 years ago, I had a 7030 do that. Only one I've ever seen.
This page was generated in 0.083 seconds.
