7020 Pulling Tractor
Barnyardpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Pulling Tractor
    Posted: 10 Dec 2025 at 11:44am
Back in the spring I got a good deal on a 7020 black belly that had been sitting 10+ years. After a new starter solenoid and some injection pump cleaning I got it running and spent the summer pulling it in out of field classes. I’m hoping to pull it in our 10k “stock” class next year. Currently all I’ve done is back out the torque screw on the injection pump and slightly advance the timing. With that being said, here’s what I need help with:
Getting it down to 10k pounds
Suggestions for more horsepower
Other suggested modifications for pulling
Class rules are pretty much 3k RPM, ag governor, motor has to match brand, and 10mph speed limit
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2025 at 5:39pm
Pretty hard to make enough power to compete in a 10k lb. class with only 301 cubic inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2025 at 8:25pm
A 7020 Power Director with a 200 lb driver and 18.4 x 38 non-PS rear wheels and 10:00 x 16 front tires should weigh 11,300 lbs with zero weights and zero liquid ballast. The 3-point hitch draft arms and lift links would have to be removed. That would be probably be 300 lbs. The regular drawbar (if it was mine) and slide hanger would have to go and I would build a pulling eye to the proper height and attach it to where the roller for the drawbar would roll on. The rear wheels would need to be removed and replaced with a set of 9 bolt dual wheels (stamped steel centers) and axle hubs.  That MIGHT get you 700 lbs. One battery and the small fuel tank will have to go. That would be 100 lbs.  Looks like the cab doors both sides need to be removed and you might just squeak by. Increased HP ?? Takes more fuel and more air and that costs money. Lastly, you don't say if it is a tractor to be farmed with AND pull twice a year at a county fair ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2025 at 8:39pm
Just a tractor to play with, have others to farm with. I hit every pull in our association with the exception of a couple that are further than I want to drive. I have a set of steel wheels, just trying to find hubs or have a set built. I plan on pulling the cab completely. I had it down to 11,320 with no driver. As far as tractors go I’m a newbie. I come from a truck background
Edited by Barnyardpuller - 10 Dec 2025 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2025 at 8:54pm
All right. So it's yours to do with what you want and how much time and money you spend on it/with it. As far as being a real competitive model to pull with, in a 10 MPH class,  it ain't.  A 7030-40-45-50-60 have 125 more cubes and will weigh only another 500 lbs or so.  The 426 engine would align better for HP capabilities that would be pulling in your 10K/10 MPH class. Your engine does much better in a 180 or 185 chassis at under 7500 lbs. If it's all in fun, then make it happen.
Edited by DrAllis - 10 Dec 2025 at 11:23pm
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2025 at 12:40pm
Yeah, in that class you’re going to be running against something 466 powered (red or green) that has 4x the power you have. D21 will be 426. If there any Fords around there they will start at 401 but most likely a 456 or 474 by now.
Edited by Jordan(OH) - 09 Jan 2026 at 9:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 9:13pm
Any way to get injpumpEd in here for a fuel/air recommendation?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 2:32pm
What everyone is trying to explain that has pulling experience, is you have the heaviest in weight tractor with the smallest cubic inch engine ever built. Most of your comp will have exactly the opposite. You can add an inline pump bigger tips and twin turbos, hardened rods and water injection - and you MIGHT be close to some in the class in hp after about 10 grand + in improvements plus your labor of about 300 + hours - then your clutches will be an issue without major rework.   The best you can do is a max'd out 7080 pump (.31)  and larger tips - with a different turbo - many to choose from - you might get 200 HP at 3000 rpm - probably half what is in the tractor line up against you - it is X$/hp  whatever you do  & Ain't no substitution for cubic inches.......
Edited by tbran - 30 Dec 2025 at 2:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 6:35pm
It would be like trying to run NASCAR with a 200 cubic inch engine. You can spend a lot of money and never be competitive.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 9:02am
Just pm me, I can build a slightly modified pump and injectors, but you'd still be behind the 8 ball with a 301. At very least, I'd suggest putting an early cylinder head on from a 180/185/190/200 or similar, to get away from the copper injector tubes, then I can build a set of injectors with the 7080 nozzles. I do a lot of 250hp 190XT setups, that don't cost a fortune because of a bunch of EDM work on the nozzles making bigger holes. I also can supply a set of drop on head gasket fire rings when I do a fuel system. The DM pump can be modified to put out quite a bit of fuel, but as mentioned above, it's best to use a hydraulic head from a 7080/7580/N6 pump with /.310" diameter plungers, vs the .290" on the 7060 and lower DM pumps on AC tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2026 at 2:30pm
Is I possible to remove the hydraulic block, 3 point control and pto without effecting anything? Or is there anything I have to do in conjunction?
7020 Farm Stock puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2026 at 7:32pm
I designed a system for a friends 7060, that eliminated the main hydraulic pump (the piston pump) and all the hydraulic/3-point valves and linkage and also removed the whole lift arm housing and 3-point hitch. He still had power brakes and diff lock and PTO. He lost a lot of weight. It is a dedicated puller. Never farm with it again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2026 at 8:52pm
It’ll never farm again, strictly a puller. Does the PTO have to stay or can it go as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2026 at 9:23pm
The lower exposed shafts could go, but everything else inside needs to stay to drive your transmission and power steering pumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 10:01pm
I eliminated all the hydraulic valves and lift arms/housing, now I’m at a crossroads on getting the brakes to work
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:11am
I just can't imagine you are going to be competitive with a 301 cubic inch engine pulling against 466 cubic inch engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:34am
Competitive or not, it’s all in having fun. Almost all of the pulls around here are benefits for FFA, Shriners, or individuals with cancer. The times I did manage to pull out a win last year I donated back anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:21am
Not knowing exactly what you have already done, makes it kind of hard to advise. On the right side of the PTO valve is/was a hose (connected to a tee) that came from the 3-point hitch valve plumbing. There needs to be 300-350 psi of oil pressure coming into that tee and your power brakes and power diff lock will then work. So, utilize the power steering return oil flow to accomplish this. Tap into the PS return line just ahead of the right hand hydraulic filter and jury-rig a 300 psi adjustable pressure making valve and a tee connection ahead of it to then run a hose back to the PTO valve tee.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 60 minutes ago at 6:00pm
Would that be the line that comes off the hydraulic oil cooler and goes into the front of the filter housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 39 minutes ago at 7:21pm
Yes.  99.9% of the PS return flow still goes thru the right hand filter. You just need to create 300 psi of back pressure in that line and send 300 psi of pressure to the PTO valve tee. The actual flow going into that circuit is almost zero, but it has to have 300 psi of pressure to make the brakes/diff lock work.
Edited by DrAllis - 18 hours 29 minutes ago at 7:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 22 minutes ago at 7:38am
So I basically just need to create a restriction between the tee and the filter housing so it pressurizes the line correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 21 minutes ago at 9:39am
Yes.  300 psi to 350 psi absolute max on the PS return. This kind of pressure doesn't bother the steering orbitrol one bit.  500 or 600 psi might. So, quadruple check your pressure especially at full throttle.
Edited by DrAllis - 4 hours 16 minutes ago at 9:44am
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 7 minutes ago at 12:53pm
It’s not just a restriction. You need a pressure regulating valve
