7020 PTO won't disengage
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 PTO won't disengage
    Posted: 12 Dec 2016 at 8:58pm
My 7020 i put it on the snow blower this year, and now if I have the blower lifted I cannot disengage the pto until I set the blower down taking load off the lift arms. Anybody know what's causing this??
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 4:53am
I am not the expert, but it could be a problem with a bent bracket, #6 below:
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 6:38am
Could need a new cable.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 6:44am
I hesitate to mention this, but I have also had this happen when the rear-end oil level got too LOW.
Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 7:21am
That #6 absolutely cannot be bent rearwards at all !! I have straightened many over the years and welded in a brace to keep them from bending again. Steady hand pressure to release....not just force it.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 11:00am
had one do this many years ago - the pto valve has 2 sump drains, if one is plugged with a sheared oring or gasket or other item the pressure from a remote or 3 point lift ram will build up in the pressure reducing circuit - this will cause harsh engagement and difficult disengagement.   The solution is to remove the pto valve and clean the sump passages in the tractor and or the valve...   if the CABLE  is not the issue.   By saying you can shut it off when the lift is lowered triggered this memory...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 9:07pm
There were some that we filed a grove in piston that holders lever engaged.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 11:02pm
Thanks for all your input guys, I had it out again tonight to move more snow and did like the Dr mentioned I firmly but slowly pushed the lever and with the lift arms up it disengaged. I guess like any cable it can't be forced. Thanks again for the help!!
