7020 loss of power |
cowkicker ![]() Orange Level Access ![]() ![]() Joined: 21 Mar 2010 Location: Ky Points: 529 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Feb 2012 at 8:27pm |
Neighbor has a 7020 that has has lost it's power. It revs slowly,has lots of gray/white smoke, and seems to have a flutter or slight miss when the throttle is wide open. The injectors checked okay, seems to have plenty of fuel getting the pump when loosening the line and hand priming, turbo feels okay, and there are no air restrictions. Thinking maybe it was the pump, I put a pump off of a 7040 on it that I know was good several years ago when I parted out a tractor. Still the same thing , no power, slow to rev, gray/white smoke. I did crack the lines at each injector and it would cause a definite miss at each cylinder at idle. Anybody with suggestions what to look for next?
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
My first thought was pump or timing, hard to believe two pumps make it act the same. Since you checked good fuel delivery, and the turbo won't affect RPMs much under no load, what fuel is in it? Filters? What does it do, if you prime it while running? Could it have gotten some gas in the diesel, I am sure you are aware white grey smoke is typically unburnen fuel, suggesting spray pattern or pump problems. I am at a loss, hopefully you will get some better ideas from others.
Still in use:
Any thoughts? Think it would be worth trying another pump?
Well If you have one laying around, then yes, but I don't know if I could bring myself to spend the money on mine to have the pump reworked just yet, since it exhibited the same exact symptoms as before even with a different pump. Yes it was a used pump, but from what I read you know that pump, how did it run on the tractor it was on, when it was removed? Yes pumps can die in storage if they are weak already, but I would find it hard to believe the exact same symptoms were displayed. It's possible, it really does sound like fuel delivery, especially the "won't rev part" Even an engine that is out of time a few degrees retarded will still rev properly, I have never found one too advanced to know what happens, but I would imagine it could handle a few degrees, as long as it wasn't under load.
Still in use:
Russ SCPA ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Southern Pa Points: 256 |
Replaced the fuel filters? My 7020 will act the same with a bad filter, also might you have a warm weather fuel blend?
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
put a pressure guage in the intake manifold (intercooler) to make sure it's building boost. Could be a blown intake gasket, or a plug has fallen out somewhere allowing all charge pressure to escape. Seen it several times on 301's!
mark vaughn ![]() Silver Level ![]() Joined: 07 Dec 2011 Points: 63 |
I had a 7045 Allis do and acted the very same way one time. Took the pump off to have it checked out , diesel shop rebuilt the pump , put it back on the tractor after checking the fuel filter and it ran the very same way. The tractor had a JD glass fuel filter on it so replaced it and tractor ran the same. Took the line off the exit end of the filter and it looked like enough fuel running out. So took filter back off and took the mounting block off. Took the fittings out of the block and could see dirt and crud built up in the interence fuel port. Cleaned the ports out, installed back onto tractor and it ran like a new one.
Put a vacum gauge between pump and filter with a clear plastic line. Check for air in fuel and vacum draw at full rpm. If it is one with electric fuel pump it should show pressure. If it has electric fuel pump also check for vacum between pump and tank.
Make sure front damper has not sliped causing timing marks to be wrong. MACK
